BCT15X: BCT15X hum
KevinC
32D2T/957.282
I'm everywhere Focker!
Got a new BCT15X, connected it to a BT transmitter via the headphone jack via a mini-mixer (just like the Uniden it replaced). The BT speaker on the other end started making popping noises intermittently, as I have several radios connected to the system it took disconnecting one at a time to find the culprit (it was the new 15X). Disconnected it from the mixer and the popping (and now hum) was still present on the internal speaker even at zero volume.
Anyone else experience audio issues on a 15X?
KevinC
32D2T/957.282
Oh yeah, please don't tell me it's the mixer or BT transmitter or cables or BT interference or the BT speaker. TIA
RandyKuff
Lorain, Ohio
So you are running the headphone jack to the mini mixer and output of mixer to a bluetooth transmitter?
And you replaced a 15x with a new one and this happened?
Why did the old one get replaced?
KevinC
32D2T/957.282
My first thoughts would have been maybe a ground loop issue popped something in the 15x...
I have a ground loop isolator inline. And unless the audio circuit changed from the 15 to the 15x the 15 it replaced worked just fine.
RandyKuff
Lorain, Ohio
Well that eliminates a ground loop issue then...
Even if the audio circuit changed, that shouldn't be affected by an isolation xfmer...
You running all the radios from one common power supply?
trentbob
Silent Key W3BUX
Bucks County, PA
Is there any specific information that indicates that this model required different Hardware, secondary to supply shortages?
tvengr
Well Known Member
Baltimore County, MD
Try unplugging the BT. Do you hear hum on the internal speaker? If so, it may be a filter cap or voltage regulator problem. The fact that is just started indicates it may be a component failure. Check your cables that there are no shorts.
KevinC
32D2T/957.282
Well, let's see...
KevinC
32D2T/957.282
I appreciate all the suggestions, but I wasn't looking for troubleshooting assistance as I'm pretty darn sure I've done it all (I'm not as dumb as I look, I couldn't be). I was just asking if anyone else has had audio issues with a 15X
tvengr
Well Known Member
Try unplugging the AC adapter and run off of battery power. The fact that you are hearing a pop indicates there may be a leakage path between the AC source and the antenna or power ground, That can set up a time constant and cause pops at a regular interval. Anytime you are dealing with multiple pieces of equipment connected together can cause all kinds of audio problems. If your mixer has a grounded power plug, try plugging it into an adapter to disconnect the ground pin. You can try the same thing if your scanner AC adapter has a grounded plug.
KevinC
32D2T/957.282
I have multiple radios on the same antenna system (elaborate filtered/amplified/multi-coupled setup) and none have issues, including the one the 15X replaced.
None of the attached equipment has a grounded plug except the UPS everything is plugged into.
I have multiple radios on the mini-mixer (which is USB powered) and none have issues, including the one the 15X replaced.
I’m not looking to fix this because as I said I’m sending it back. The existing setup has worked flawless for many, many months now so I highly doubt it’s a design issue. I was just curious if anyone has had audio issues with their 15X.
