Before you buy the USB-1 cable
Gbcue
CA
I got my serial-USB cable on eBay. It's a silver/aqua colour one that is a "HL-340". I installed the drivers from the supplied disc and it works fine! Great product for about $5.00!
tommybza
nw indiana
This sounds great my question is this exactly what i need to work with my 245xlt,
and then i should down load the driver from uniden correct?
sorry if these questions are so basic but i do catch on kinda eventually ,
it took me a lil time to get my pro 97 programed and well worth the time spent ,
Thank you
Tommy
UPMan
In Memoriam
Arlington, TX
You get the driver for the cable from the company that made the cable, not from Uniden.
Dubbin
Findlay Ohio
Why not the driver from Uniden? It works just fine with this cable and adapter.
country2
Homer Georgia
Don't laugh but I've been trying for 3 hours to get a darn driver to install on my Vista Ultimate 64 bit. I've tried 3 different drivers so far and all was suppose to work on Vista 64 but I guess my computer didn't know that. The drivers from prolific and Moschip (unistalled each and rebooted before installing the other) after installation windows now says " This device is not configured correctly. (Code 1)
The name is already in use as either a service name or a service display name."
Any ideas? I'm almost at whits end and I'm out of beer!!!
The device is being seen by windows and even shows as a prolific USB controller (port 9 the port number seems to change after every uninstall and reinstall of the driver)
I would try the Uniden driver but I cannot even locate it on their webpage. The direct link that was posted here a while back just sends me to my login page and when I log in still cannot locate a driver for it. thanks
Dubbin
Findlay Ohio
Its in the files section on the 396 yahoo page.
toonman4
McHenry Co.
If you got it from monoprice, send them an email about it
I did that with mine and they are shippping me out a new one to try to see if mine is defective (didn't even ask for the old one back)
country2
Homer Georgia
Thanks for the info. I don't think its defective as its being detected just seems to be a driver problem or better yet a vista problem (stricter guidelines) Going to try a few other things and even going to install xp on a virtual drive and make sure the cable is good. Now one thing I didn't mention is that if I install the driver from the included cd it give a driver corrupt or missing files error.
UPMan
In Memoriam
Arlington, TX
If the cable does use the PL-2303 Prolific chip, then the drivers on Uniden's site will work. However, it is difficult for a general user to know what chip was used in the cable...so the advice stands as "Get the driver from the original vendor."
Country: If your cable uses the PL-2303, then the Vista 64 drivers on Uniden's site should work (they did for me...both using the USB-1 and "iConcepts" cable that also used the PL-2303).
country2
Homer Georgia
Thanks UPMan for the advice.Since its being detected as Prolific usb to serial device almost positive its the pl2303 chipset. Was going to run the serial number on it but...errr there is none. Well going to install my image backup in case with all the drivers I tried maybe something didn't uninstall completely then I'll take it from there and last step will be running xp as a virtual....
country2
Homer Georgia
All working now. Don't know if was that a driver hadn't fully uninstalled or what but after I installed a clean image and used another driver it works now!
Smerri
Massachusetts
I am bringing this one back from the dead. Purchased one last Thursday so I could program with my laptop, received it today, and it works great. Installed my drivers and everything is all set.
Certainly worth the $10.00 I spent (Item + Shipping) and would recommend to others who need it.
pappy1
Central Arkansas
OooK, where did you get it?
hiegtx
Dallas, TX
Can someone point me to where to download the Uniden usb driver? thanks
Easiest place to get that is from the page on ScannerMaster's website for the USB-1 cable.
Click here
You'll see download links on that page underneath the cable.
G3MiNi
Usa
Great Information! I just bought the BR330T, and ordered this cable. Saved over $20. Brilliant!
