Bendix King KNG2 p-150 display issues
emtbls1987
Does anyone know why a Bendix King KNG2- p150 screen is showing just white when powered on. Doesn’t show BK technologies when powered on just white screen?. It acted like this the other day and I just pulled the Battery and placed it back on and worked fine. Know that doesn’t work and leaving it off does help either. Could this be due to the Heat outside or leaving it under a coat and getting to hot ???
rsmith7799
Arroyo Grande, CA
Good morning, you can start by updating the software. If that doesn't work then you will need to send it back to BK for repair. Look to see if you have the serial numbers between 1006010121120001 thru 1006030122040135.
