shirsch101
What’s the best HF non SDR Donglr radio under $500
Probably a portable but would prefer a desktopReally? That question is about as wide as a barn door. Desktop or portable? Ham radio transceiver?
The HF Desktop market is gone; you are left with ham radio transceivers that often have a general coverage radio built in, or a high end portable such as the Tecsun H-501 or the Belka. There are wide band radios like the Icom R-8600 that can fill the bill if you can bump the budget.
Category:Receiver Reviews - The RadioReference Wiki
wiki.radioreference.com
Mike
What are you looking to listen to, broadcast stations, utilities, hams SSB or CW...?What’s the best HF non SDR Donglr radio under $500
The R-5000 was *the* receiver of that era (late 80's - 90's), and was found in the shacks of many serious DX'ers. Just keep in mind that the R-5000 was introduced in 1987 and the oldest units are closing in on 40 years old. The R-5000 has a known issue with keyboard bounce, and the "dots" issue where the numerals in the display show up as dots. The "dots" issue is usually cured by replacing the internal memory back-up battery, which is soldered in. Also, figure that it has aging electrolytic capacitors that may need to be replaced.Kenwood R-5000.
You can get one in good condition for well under $500 if you take your time looking.
He does need to bump the budget and his allowed answers. Picking "the best" when you have eliminated most of "the best" makes picking hard. And in this case, *some* of us see 4 categories: inexpensive portables that some think are good (but we disagree)*, SDRs around $200 which are very good, and expensive receivers or transceivers that are quite a bit more expensive.Really? That question is about as wide as a barn door. Desktop or portable? Ham radio transceiver?
Mike
The R-8600 would require the OP to quadruple his budget, though there are new HF transceivers that are cheaper. Even a used R-8600 would be well above the OP's $500 budget.He does need to bump the budget and his allowed answers. Picking "the best" when you have eliminated most of "the best" makes picking hard. And in this case, *some* of us see 4 categories: inexpensive portables that some think are good (but we disagree)*, SDRs around $200 which are very good, and expensive receivers or transceivers that are quite a bit more expensive.
* Footnote: If their were actually good "best" cheap radios, there would not be expensive ones.
IMHO, $500 is sufficient to score a good older tabletop receiver that was top of the line in its day. Properly aligned, they are hard to beat even today.
Agreed, the R-5000 is a good one to consider, as is the R-1000 and R-2000. The R-1000 appears to be especially reliable, per reviews on Eham.I agree that the receivers being mentioned are still competitive with newer models, and that if you take your time looking that $500 is easily enough to get any of the Kenwoods (1000/2000/5000) and Icoms (R70/R71/R75). However, it is probably not enough to get a JRC receiver (515/525/535/545) in good condition. It's not not nearly enough to get a Drake R7 and probably just barely enough to get a well kept Drake R8.
That's why I recommended the R-5000 as perhaps the best available desktop choice for the OP's budget based on my own experience, but the Icoms are also well worth a look.
Where are you seeing a R-30 for under 700 bucks? Just curious.Squeeze the wallet a bit more and grab a used Icom R30 for under $700. To give you an idea of the valuation over time, I purchased a used Icom R30 in 2020 for $400. For a RX comparison, the selectivity and sensitivity are improved over a Kenwood D74 amateur portable that offers HF receive as well. Of course, the R30 is a dedicated receiver.
Eh ya that would almost make me go after it and I don't need it. I've got enough to receive on around here but.....The R-30 is a handheld receiver and the OP is looking for a desktop. $700 for a used R-30 would be the deal of the century.
but to be honest an R-30 would put most the others mentioned to shame capability wise.Probably a portable but would prefer a desktop
