1-1-2019.
Best Rechargeable Batteries as of 1-1-2019.
Best Rechargeable Batteries. {January 3rd, 2006. Day of the Week: Tuesday.} For the year 2019, please.
https://forums.radioreference.com/threads/best-rechargable-batteries.27720/
You say that he threads are buried in the past somewhere like 2014-2015, how about some Rechargeable Batteries threads are from:
Jan 3, 2006 or before?
Not open for further replies. Then do we make another thread?
Where is the right place to put the rechargeable batteries topics at?
Stay on topic.
Start a new thread if it isn't on topic for the existing one.
Required to post in the correct forum.
All replies to a thread are to be on-topic or within reason.
I don't want to be making duplicate cross-postings or reposting something that is already said.
should we not keep repeating and re-making the duplicate rechargeable batteries threads or is each one with a different topic about it?
https://forums.radioreference.com/threads/rechargable-aa-batteries-best.114054/
This subject has been beat to death also.. do a search peopls!!!
AA and AAA Battery Chargers | ThomasDistributing.com
Products - Chargers - Maha Energy
What is the difference of a: Maha C9000 Battery Charger, {Part Number: K-MHC9000} Vs. the Maha MH-C9000 Advanced Battery Charger, {Part Number: MH-C9000}? Or is all of the C9000 the same ones? This one calles it the: POWEREX MH-C9000 WizardOne Charger. Which is the: SKU: MH-C9000-0000GS, and B&H # POMHC9000 MFR # MH-C9000-0000GS.
https://forums.radioreference.com/threads/what-rechargable-batteries.346863/
Jan 23, 2017
I am sure this has been covered, but, what rechargeable batteries?
https://forums.radioreference.com/threads/adequate-batteries.353539/page-2#post-2768281
May 24, 2017
Anything better or other people use different th
en the Panasonic Eneloop Pros Vs. Powerex Pro 2700mAh or about the same?
Energizer L91SBP-12 Ultimate Lithium AA Universal Battery - 12pk
Or how about compared to Energizer Ultimate Lithium?
https://forums.radioreference.com/threads/rechargeable-batteries.354798/
Jun 18, 2017
https://forums.radioreference.com/threads/calming-some-scanner-fears-and-comparisons.376265/
Sep 5, 2018
https://forums.radioreference.com/threads/whistler-trx-200.379778/#post-3033365
Dec 11, 2018
https://forums.radioreference.com/threads/gmsr-and-batteries.238521/
1.6V
https://www.amazon.com/Powerex-MHR9V-230mAh-Rechargeable-Battery/dp/B0002LAKOS/ref=sr_1_4?ie=UTF8&qid=1546393805&sr=8-4&keywords=powerex+9v+batteries
What is with a 9.6V and 1.6V batteries?
Is a rechargeable 9v discussion for this thread or an entirely different post, thread, or forum? Most look for aa rechargeable? Do some rechargeable batteries have or not have a rechargeable 9v?
https://www.bestbuy.com/site/panaso...e-aa-batteries-4-pack/5467065.p?skuId=5467065
Are the eneloop items is no longer available at best buy, radio shack or Batteries Plus Bulbs or which one has them?
eneloop 8pk AA with 4-Position Charger
LaCrosse charger problem or Eneloop problem?
rechargeable-battery-review.com
discharge/refresh several times in a row, you say.
Do the math for me, please.
At 800 minutes a charge
However much time for discharge for 100 ma to 1,000 ma
For 12 cycles if you use the cycle mode
For 9,600 minutes
Equals = 6. something days?
Or do you set it at charge rate at 200 ma or 2,000 ma?
"When tested using the REFRESH/ANALYZE mode, the capacity will be lower than the capacity on indicated on the battery. To obtain a capacity that is closest to the rated capacity, use the BREAK-IN mode.":
FAQ MH-C9000 - Maha Energy
(Well over 100), how long does it take to charge all of the ones you need for the next day if you had two sets of them for each device per day and didn't get enough time to recharge them for two days, and do you just use more then one battery charger to make it quicker, or am I missing something altogether?
What number of recharges are you on for each of your batteries and did you only use them half way, how many of the time, or should we not keep repeating the duplicate rechargeable batteries thread or is each one with a different topic about it? I can't find the thread that was about January 2018 wanting new information about batteries in an older forum thread, can someone find that thread for me?{ i think I found it and can still post in this thread, thanks. Can we only have one thread about all rechargeable batteries, unless it has sub categories about different topics about rechargeable batteries? Anything I missed please add, thank you. Thank you. Thank you again.
