A while back, I discussed building a harness for a Commscope dipole that I was given. My goal is to split up the two 224A's into four 222's (2 element) for scanner feeds. I've never built a phasing harness before, antenna building is definitely not my specialty.. the good thing is, I have a virtually unlimited supply of RG-11 thanks to work, so if I need that for a harness then I'm set (someone sent me documentation that indicated Commscope uses 75ohm (RG-11) and 35 ohm (RG-83) coax in their harnesses. What's the most effective way to build a new harness for these antennas, with very little "proper" equipment for measurement?
