Bethleham area help
Deespag
Hello I just recently purchased sds100 but had homepattol2 and bcd325p2. Do you have any advice for clear reception I live in Bethlehem area. I thought upgrading to 100 would be better but don’t know everything about this scanner.
Whiskey3JMC
Lemme show ya sumthin
Simulcastylvania, TE
Welcome to the RR forums. What are you using as an antenna on the SDS100? You should expect simulcast distortion on the other two scanners so I'd forget about tracking anything simulcast using them but you should have a pickup on Bethlehem's trunked radio system on the 100 (which is optimized to deal with simulcast systems) if you're within system coverage. Toss the 100's stock antenna aside if you're still using it and pick up a REMTRONIX REM-820S which is optimized for 700-900 mhz reception. If little to no improvement, try experimenting with different filters. What's the RF environment like where you are? Any cell towers in close proximity?
Lastly, keep in mind that all law enforcement is fully encrypted in Bethlehem as is every mode "DE" talkgroup in the database so no scanner will be able to pick these up. Also, be sure all service types are turned on for the talkgroups you want to hear (reference "tag" column in the RRDB). By default only EMS Dispatch, Fire Dispatch, Law Dispatch, Custom 1, and Multi-Dispatch are enabled, the rest will have to be enabled by the user as needed
Deespag
There’s a tower close plus all the cell stuff on top of buildings. Yes I know about my police being encrypted so that is why I had to look for other stuff to scan. Right now I have that bcd325p2 hooked up to working decent but wanted better
Hustler DCL-B Discone Base Station Scanner Antennas DCL-B​
Deespag
So got the 820s and have tried all the filters still very frustrating with reception. I see people saying Northampton county radio will be changing soon?
JimBobTerp
Easton,PA
Hey, if I knew how to do it or if I could figure it out, I could maybe program it for you, but you would have to bring me the radio to my job and see if I could do it in my car real quick to get it to work for you.
Deespag
Can you explain more let me know are you serious
JimBobTerp
Easton,PA
Like if you could bring the radio to my job and I can maybe look at how to program it for you to get it to work. I think that has to come with a AC adapter so you might have to plug it in your cigarette adapter, but I’ll see what I can do to try to get it to program correctly for you to make it to work right
Deespag
Anyone live in ABE area and use SDS 100? What setup do you use filters antenna
jtwalker
BEE00.1E8
Filter usage will vary from one location to next. Even one house to house across the street, so what works for someone probably won’t be ideal for you.
NCFA
Plainfield Township, Pa
I noticed County South PD is utilizing two different CC 851.912500 and 853.887500. I live in Plainfield Township so not sure if this is off a new tower or Bethlehem's site. I submitted that to the database this morning.
Deespag
Yeah I have noticed it coming up on scanner 3 different ways ID 11007 CO PD South 1 and NC PD South 1. The fact it’s listed with Bethlehem mean anything like encryption in future just wondering.
NCFA
Heard all PD will be encrypted once it’s up. The NAC for CC 851.912500 and 853.887500 is NAC 2A3. I programed all the fcc frequencies that were posted here not long ago and those two just started hitting.
What's the best program to get the
System ID, WACN, RFSS, and Site ID
Deespag
What do you mean by all PD in Northampton county? Is Easton different? And I never thought all these little town boroughs would go encrypted am I crazy for thinking this?
u2brent
OAMPT
KRWDPAXKRS1
Might wanna get your head wrapped around the idea, E is coming to all Law Enforcement, everywhere. It's not just a big city thing .
NCFA
All PD, Easton, East PD, South PD and North PD I would assume if they follow what they are doing with Bethlehem, EMS will also be fully encrypted.
maus92
OCMD
MSP Belair Barrack on FIRST is not encrypted.
u2brent
OAMPT
KRWDPAXKRS1
Yeah, but they are not on CMARC any longer. My reposting was directed more towards Harford LE encrypting. As every little nook and cranny of LE will eventually be nationwide.
