Big Truck Radio 12V Source Upgrade
slowmover
Fort Worth
This monster ferrite is one I obtained from Palomar to quiet a portable NORCOLD 12V refrigerator/freezer that — when the compressor kicked in — completely blanked RX. (Zero, Nada, as if the radio had failed).
Didn’t matter if I ran it on 12V or from the inverter on 120VAC.
That’s about 11-12/turns, the maximum I could allow.
Barely heard it afterwards.
CORNELL-DUBILIER and NEWMAR are industry sources for various applications of devices to treat RF offenders.
slowmover
Fort Worth
I’ve learned with big trucks:
30A @ 25’ total circuit length
6-AWG
Runs a mobile radio rig pulling a temporarily steady 20+ Amps just fine. Leaves room for resistance hiccups (ambient heat, splices, etc). Length isn’t always this great, but “Six” will get the job done somewhat shorter & longer.
“Six” is also easy to work with unlike anything larger.
In the same way:
100-150W per antenna (mobile) gets the RX/TX “equal distance match” done given NRC-radio.
I use this as goal. Might get over/under on either, but it’s million-mile true for reliability over time.
3% = 1/2V
Quiet. The truck doesn’t know it’s there.
slowmover
Fort Worth
Didn’t take notice that an Iowa-Class DC Noise Filter was hidden in these pages:
Impressive, @prcguy.
prcguy
It’s only got an 8.3 Farad capacitor across the choke, what’s the problem?
slowmover
Fort Worth
There’s more THERE there than I’m used to seeing. Plus your quote “nothin gets past”. Kinda big for mobile, but I’ll bet someone will want to try to duplicate that.
prcguy
I don’t use it mobile as I don’t have any noisy vehicles. I built it mainly because I had the parts laying around. Just another one of those things here looking for a purpose.
slowmover
Fort Worth
I’ve had the above to contend with. In the truck, but not of it.
I’ve also wind of a project where what’s below isn’t up to the task.
jcrmadden
"...my ultimate DC line filter I built from scratch using a 40 amp rated 41.7uh choke and an 8.3 Farad 16 volt capacitor as a choke input filter with overvoltage and spike protection. Nothing gets through that filter and it has four 45A Anderson Power Pole connectors on the output side and a 40A aircraft circuit breaker."
Can you make it bigger?
