BK M-150 Dual Head Programming Problem
Reese
El Dorado County
Need help, I know there are KNG M-150 experts out there.. I am a wiz at Motorola, but this KNG Radios are a different animal.
So, I can program a KNG M-150 no issues. One of our Chiefs Buggy has dual head. I could never get a green light on the R.E.S.
Is there something special that needs to be done to talk/program a dual head?
thank you
Reese
KK6ZTE
California
Program via the deck, not the head.
Make sure the head baud rate matches the deck.
Make sure you update firmware on both heads, then the deck.
rsmith7799
Arroyo Grande, CA
What KKC said. Also once the installation is complete. hold the HOME BUTTON on the control head while powering up the unit. A Configuration Menu will appear. Select Control Head Address, use the Up/Down arrow to select. Press ENT to set.
Send me a IM if you have other questions.
Reese
El Dorado County
Thank you both for your input. I ended updating the firmware in both control heads. That allowed me to program the radio.
