Blanco County Changing Systems?
Wes
Austin, Texas
Just FYI, the LBJ bike ride will be on BL Ops 3 for anyone searching for new talk groups tomorrow.
rbarker
Robert
Austin, TX
The Marble Falls 155.5875 control ch is silent but appears to now be on 151.1075 with the audio on 154.0475
Hill country talkgroups so far:7067 Blanco PD?
7072 Blanco SO 1 ?
7088 Blanco FEMS 1 FEMS= Fire and EMS
7089 Blanco FEMS 2 300's Blanco
7090 Blanco FEMS 3
7165 Burnet Op1 Operations 1
7170 Burnet PD Dispatch 1 city and county north
7195 poss Marble Falls PD
7204 Granite Shoals PD units 600's
7210 Burnet PD tac
7211 tac
7220 Burnet FEMS
7221 Burnet FEMS PD Medic 21 on scene
7225 Burnet FEMS Dispatch Fire & EMS dispatch 154.415
7226 Burnet FEMS 5 north units including Briggs and Bertram
7227 EMS at Seton Highland Lakes ER
7230 Fire Tac Bertram FD units talking to each other
Wes
Austin, Texas
I'd be willing to bet almost anything that 7066 will be BL OPS 2.
rbarker
Robert
Austin, TX
Hearing "Llano" today on talkgroup 6975
also:
7222 Bur FD/EMS2
7223 Bur FD/EMS3
7225 Bur FD/EMS north simulcast 154.415
Wes
Austin, Texas
7225 will probably be an "alerting" talk group, which simulcasts the VHF pager frequency.
Wes
Austin, Texas
Didn't hear any traffic other than a key-up, but 7265 seems to be another talk group on the Western Regional radio system.
jfstx1
Texas
Wes I have a quick question for you. I just got the 996xt in this morning and set it up to search. Should I just search 150.000 to 160.000 or do you recommend something else? I have it hooked up to a base antennae that is about 30 ft in the air
Wes
Austin, Texas
Where in Blanco County are you? I'd program in the closest tower and then just leave it open to search for new talk groups.
jfstx1
Texas
I'm in Johnson City. I have all the Blanco County channels programmed in. I was just curious as to what would be best for searching. Thought I could help with some channels/ tgid's.
Wes
Austin, Texas
Program in the JC tower, then leave it in search, rather than only scanning the talk groups you've already programmed in. I'm in JC today if you need help.
jfstx1
Texas
thanks. I have been listening to dps and picking some up out of Sulphur Springs. I assume by J.C. Tower you mean the 3 frequencies listed in the data base
Wes
Austin, Texas
Yes. You'll need to program the 3 JC frequencies and set it up as a trunked system. There should be an explanation in the manual as to how to do that.
hiegtx
Dallas, TX
Are you programming by hand, through the keyboard? Or are you using software and your pc to program?
hiegtx
Dallas, TX
by hand so far
The Easier to Read manual has step by step instructions for creating a trunked system. Easier to Read BCD996XT Digital Scanner Manual
Have you created a trunked system at all? Or just, so far, added conventional frequencies from the database page.
Since you're a Premium subscriber, you could use software, such as FreeSCAN, which, as the name implies, is free, to download whatever systems you wanted. Much quicker than by hand, and more importantly, you can see most all of the information needed at the same time. That makes it much easier to spot and correct simple errors and omissions made during data entry. If your pc does not have a serial port (labeled as COM 1), see Connecting scanners via USB - The RadioReference Wiki
The scanner should have come with a serial cable. If you do not have a serial port on the computer, there are a number of USB->Serial converter cables available, or simply get the Uniden USB-1 cable. Links are in the article linked just above.
Also see Program your DMA Scanner - The RadioReference Wiki
