bloomfield trs
800crazy1
CHICOPEE
just checked the data base and someone posted that bloomfield is dropping the passport trs as of today april 9th and will be using conventional uhf again . anyone know the freqs they'll be using ?
cg
Connecticut
same freqs just in conventional mode w/ PL & DPL's
As of 1530 today the Passport is still clicking away.
chris
jb872033
Cromwell CT
> 452.2500 MHz D464 Town DPW
> 453.2625 MHz 192.8 Fire Common
> 453.4000 MHz 146.2 Bloomfield Center Fire
> 453.6625 MHz D662 Townwide Common
> 453.8250 MHz 167.9 Blue Hills Fire
> 460.0500 MHz 123.0 Bloomfield PD Channel 1
> 460.2125 MHz 136.5 Bloomfield EMS
> 460.4625 MHz 127.3 Bloomfield PD Channel 2
jb872033
Cromwell CT
you got it...any ideas why they are reverting?? service troubles? havent heard much on that front...would be interesting to know the reasoning behind it
800crazy1
CHICOPEE
no , like i said , i first heard about it when i was checking the data base . would like to know why too.
cg
Connecticut
There have been numerous complaints, mainly from the PD, regarding the system operation. Some had to do with the time lag for affiliation to occur. Others were coverage I believe. Marcus did the first install, I think CT Radio took over and then Bearcom was the last system manager. No one was able to get the system working to the satisfaction of the users.
I thinnk a UHF Motorola Smartnet TRS would have been very effective in Bloomfield but the costs were likely the prohibitive factor.
chris
800crazy1
CHICOPEE
kind of reminds me of windsor when they tried passport trs and they couldnt get that up and running right either , before they got the standard system working ....does anyone know why the windsor fire dept. isnt on the ltr system ...at least last i checked it wasnt. they were still using there old original freq .
Alarmroom
East Hartford, CT
Bloomfield
Bloomfield is switching today 4/10/08 to an all UHF conventional radio system from the former Passport system
wesct
Connecticut
joetnymedic said:
keith,
any ideas as to the new freqs? are they listed on the fcc database?
wesct
bluefox2163
are you sure these are correct I have been listening for almost an hour now and have not heard even one transmission on any of these freqs...
MarkB513
Cheshire, CT.
Bloomfield
Police #1, Blue Hills Fire, Center Fire and Public Works have been in use since
yesterday morning with the listed DPL's/PL's.
cg
Connecticut
I monitored these just now:
BPD 460.0500 123.0
BEMS 460.2125 136.5
chris
jb872033
Cromwell CT
to the best of my knowlege these are the right frequencies i posted...up to you weather you want to use them or not
JB
MarkB513
Cheshire, CT.
Bloomfield
Everything seems to be correct for all. The only problem is they forgot to turn up the volume !!! The audio seems to be just as low as the dreadful Passport system.... I noticed that 33.720 is now simulcasting the Center Fire 453.400, but does anyone know if 151.220 is doing the same with Blue Hills 453.825 ??
awasser1
Apache Jct, AZ
Yes Mark I beleive so 453.825 is simulcasting with 151.22. Blue Hills actually uses that freq for tone out. I havent heard any fires yet though for them...Police volume is extra low...fire seems ok.
