im using 1 i bought this spring that was nib. works greatJust bought a pro-163 on ebay cheap. Fortunately my counties are still analog.
Good unit? Bad unit? Anything I should know?
I have 2 of its twin, the GRE PSR-400. They're not bad at all, but I prefer my Uniden-made scanners. The GRE models, at least in my experience, don't pick up as much as my Uniden ones do. I do run a PRO-197 as well, for local P25 phase 1 stuff. It does a nice job decoding digital. In fact, it probably does that better than the Unidens do.Just bought a pro-163 on ebay cheap. Fortunately my counties are still analog.
I got a 197 and its another fine scanner.its on moswinI have 2 of its twin, the GRE PSR-400. They're not bad at all, but I prefer my Uniden-made scanners. The GRE models, at least in my experience, don't pick up as much as my Uniden ones do. I do run a PRO-197 as well, for local P25 phase 1 stuff. It does a nice job decoding digital. In fact, it probably does that better than the Unidens do.
Union and Snyder counties in Pa. Happily these along with Lycoming and Clinton are still analog. Otherwise I'll use it for aircraft.What is your city, county, and state so I can take a look at the database? Did you get a programming cable with the scanner?
Stereo-just looked.Almost everything in those 4 counties is still analog. Does your programming cable have a mono or stereo connector? It may have an adaptor on the end.
Good! That will work with the PRO-163. Check if the scanner can receive the local NOAA weather frequency. If it works OK, I suggest you consider purchasing the ARC300 programming software. It will make your life a lot easier entering all of those frequencies. You can setup a separate bank for each county.Stereo-just looked.
I already have the win97 abandonware and a fully programmed Pr0-97. Can I read the 97 into the software and blow that into the 163 or is that asking for trouble?Good! That will work with the PRO-163. Check if the scanner can receive the local NOAA weather frequency. If it works OK, I suggest you consider purchasing the ARC300 programming software. It will make your life a lot easier entering all of those frequencies. You can setup a separate bank for each county.
Ah! Thanks for all of this help, it is very much appreciated. I'll probability go with ARC as I have it for the bc125 and works fine.According to the Starrsoft website, Win97 supports only the PRO-97 and PRO-2055. There are a several things to try. Can Win97 export to a CSV file? ARC300 can import a CSV file. You can also try copying from the Win97 file and pasting into ARC300. You can also try coping from the Win97 file and pasting into an Excel file and then pasting from the Excel file into ARC300. ARC software has an Excel-like editor.
Dont tell that to my pro 163.i got it 6 months ago nib at auctionThe display on the PRO-163 as well as the PRO-2096 have a tendency to fade for a number of reasons. Sometimes it's due to a loose ribbon cable connecting the LCD.
Yeah really, mine's good for now.Dont tell that to my pro 163.i got it 6 months ago nib at auction
