Brampton Fire Structure Side I.D.
irontober
Brampton,Ontario
Hi ,
Listening to a fire on Kennedy road in Brampton and my question is this;When sectors call in position in relation to the structure i'm assuming alpha side is front facing ( street side or front door ) , now is bravo side to the left (clockwise from front ) or opposite alpha (rear or back door) and the same for charlie and delta ?
Thanks,
Ron.
smokey1300
Ilderton, ON
Actually A, B, C, D are the exposures.
Fire attack, rescue, RIT for example would be sectors that tie into fire ground accountability systems.
~S
unlisted
Western Canada
Alpha side is primary staging side (Side of first due apparatus) which is NORMALLY the front/address side of the building.
Bravo to Delta are going around the structure clockwise from this position. If there is more than 4 sides, well, there is Echo, Foxtrot, etc. But that can get confusing, and IC normally sections it off another way...
DaveH
Ottawa, Ont.
Interestting, talked to a local firefighter recently, who said Ottawa uses side 1-4
for outside and A-D etc. for inside walls.
Dave
