Brant County Fire
icarus1963
Brantford, Ontario
The Brant County Fire Service has changed from their NXDN system to DMR. All comms are taking place on 152.780, which was the old paging frequency. Paging and dispatch are now both done on this frequency. Paging is done on slot 1 with dispatch and other comms on slot 2. I will submit the info to the database.
Andy
icarus1963
Brantford, Ontario
It looks as if each station page has its own talkgroup. I do know they are now carrying Unication G5 for paging.
ATCTech
Brant Dispatch is talking with Spectrum Communications tech as I write this. Doing an Emergency Signal test from one of the radios as a demonstration.
Muxlow
Super Secret
Middlesex County
You say each station has their own talkgroup? What happens when 2 stations are on 2 different calls on TS2? Do they have a simplex tac channel or something for fireground operations?
Seems odd for each dept to have their own group...But spectrum does do strange things
mikewazowski
Forums Manager
Oot and Aboot
I wonder if they're simulcasting the pageouts in analog? I don't see 153.845Mhz anymore so it might be a possibility.
icarus1963
Brantford, Ontario
The G5 is also dualband which they wouldn't need unless it's actually the G4 they are carrying?
They were definitely G5's. The picture I saw on twitter showed an old style Motorola pager beside the G5 with the caption "out with the old in with the new."
mikewazowski
Forums Manager
Oot and Aboot
I wonder if they're paging on Brantford's 800MHz system?
A G5 doesn't make any sense at all unless they've got some sort of analog paging. Something doesn't add up.
mikewazowski
Forums Manager
Oot and Aboot
Is the system meant to provide paging coverage outside of Brantford and about the only way the G5's will be useful if they are on the system is if they setup individual groups for each station.
Forts
Mentor
Ontario, Canada
I'm curious why they ditched the NXDN system so quickly (relatively speaking..)
VA3SOM
Ontario, Canada
My guess is maybe reception issues with it given how rural Brant county is outside Brantford?, or maybe they were having repeated tech issues with it?.
