w1av
- Joined
- Jan 12, 2006
- Messages
- 81
- Reaction score
- 4
I just got my Whistler WS1025. Been listening to it for 2 days now using the built-in whip antenna. I live in a reasonably high area of town and listen primarily to aircraft and fire/rescue. I am planning on installing a discone antenna up on garage roof for added range.
The first BIG NEGATIVE about this radio is the absolutely SLOPPY and LOOSE squelch. It's pretty useless. Even when turned up to full it doesnt squelch out annoying weak and noisy signals. Audio is rather tinny, but usable. The backlit amber LCD display is pleasing. One more slightly negative thing is the USELESS signal strength meter. No matter what level of received signal strength, the meter will still read full scale. So the meter is basically of no use. The case is pretty durable plastic. The buttons are very good quality with nice, tactile feel to them. Programming is very easy. All in all it is a nice scanner. BUT....monitoring can be frustrating with the crappy squelch because you can't squelch out annoying weak and noisy signals. It might be possible to bring radio to a shop and have them replace the squelch, but its probably a cheap circuit directly soldered to board. Also it might be possible to manually adjust squelch with trim pot inside radio, but pretty much everything now is all surface mounted with no way to adjust. I have a cheap Realistic scanner I bought in 1999 that doesnt have the crappy squelch like the Whistler. Not sure if I would buy another Whistler scanner.
