ProScan Broadcast Lockout
southernCTscan
Branford, CT
I can't seem to find any new info about this. On ProScan the broadcast lockout feature works well except on Trunked Systems. I have tried every combination of frequencies, sites, systems and talk groups but they still get through. Has anybody successfully done this for trunked systems. Conventional system lock outs work well! I had to shut my feed off because what I want to broadcast and listen to are different. Thanks!
eaf1956
Evansville, IN
Just enter the TG ID like for example 205
# BROADCAST LOCKOUT FILE (SOURCE CLIENT)
# Add Frequencies, Talk Group IDs, And Channel Names Not to broadcast.
# "SYS=[system name]" Specify a system name on conventional systems Or site name on trunking systems if desired to match with system Or site. See examples below.
# Text after # pound character are comments.
# EXAMPLES:
# 484.2875 SYS=LAPD
# 4208 SYS=Aerojet
# 0-01-002
# 11Fh SYS=Aerojet
# Ontario PD SYS=Aerojet
205
Do NOT put the # symbol or it will be ignored.
eaf1956
Evansville, IN
Thank you. Yes, I did that and it still passes through.
Make sure the scanner format is the same as what the lockout file has.
Decimal or Hexadecimal for p25 systems
AFS or Decimal for EDACs
Sent from my SM-N960U using Tapatalk
southernCTscan
Branford, CT
Thanks eaf1956, I emailed Bob and he fixed it in the program. I would imagine he will address this in a future upgrade. It works well now.
