SDS100 vs SDS150
NS9710
Niagara Falls, NY
A few questions here, I owned two SDS100s, and I loved them for the digital capabilities, and the performance on trunked systems, however I absolutely went bananas with conventional frequencies, especially on railroad, maritime, aviation monitoring with the SDS100 was pretty decent, now for a few questions, I seen so many posts, and reviews across the internet that I have more questions than solid answers I need to have a clear understanding on before I go dropping $1,100+ on something I'll regret, which is hard for me to say, Uniden has won me over from other manufacturers.
First: Does the 150 do better on simulcast than the 150 or are they both pretty even performance, again, as I said, the 100 was perfect in this field (atleast for my money) not sure how they could improve on that, but they may also have gone backwards.
Second: I seen as of late P25 (and I think a few other various formats) have started with TDMA sites, does the SDS150 track this feature, what about the SDS100 (I figured it would just be a firmware update).
Next: Has the SDS150 improved in the conversational fields, or is it pretty much identical to the SDS100 in this regard?
Finally: Aside from the obvious standard features on both models, is there anything else in the operation that makes the 150 a better option aside from it being the newest product from Uniden?
Feel free to mention anything relevant to any of this that I may not have asked about, again, I'd love to get a 150 because of drop in charging and so forth, my main concern is out of the box performance, I'm well aware of additional antennas and so forth will add range and performance increases in specific areas.
Thanks for any information that is given.
NS9710
Niagara Falls, NY
I was just wondering if there was more definitive answers now that people had time to really try these 150s out
Drkatzjr45
Emeritus Member
Hollister MO
I just purchased a SDS150 and I find no appreciable difference between it and my SDS100.
I actually like the SDS100 better - and feel that it is actually a better built scanner.
This obviously only represents my opinion, but to any perspective buyers, I would seriously contemplate it before purchasing this scanner.
noaim
Milwaukee, WI
battery issues and broken battery doors on the 100 sucked. They fixed that on the 150. I definitely hear farther on the 150 and the gps and Bluetooth are nice bonuses if you were to buy a gps kit for the 100 its almost as much just in that. I think its the same with conventional. I really like the upgrades
Chris0516
Pittsboro, North Carolina
I have never had a problem with the battery and/or, door. o_O
J-Wrock
Kansas City Area
I'm not going to argue or even discuss whether the 100 or 150 is a "better" scanner as it all boils down to personal opinion and what features one might think is worth or not worth it. I've previously mentioned what features of the 150 I personally like, but to each their own and, fortunately, not everyone is me so they are entitled to different opinions :) However, I will say the comment about seriously contemplating it before purchasing should apply to any major purchase, especially something like the 150 that costs in the neighborhood of a thousand dollars (US). That's a lot of money!
Drkatzjr45
Emeritus Member
Hollister MO
I had a post in this thread that was erased and I would like to know why.
I used the word vociferous in a review and got hacked by it. Now it is gone.
OpenSquelch
Vermont
150 hands down. I have had both, the upgrades made the 150 are absolutely worth it. UHF sensitivity improvement, USB-C charging and the cradle are a no-brainer. BUT, if you just have analog systems around you it may be overkill.
mikec10
Schenectady NY
I just ordered my SDS150 from Main Trading Co. I should receive it on Monday. I traded my unication G4 and got a good deal. I am looking forward to seeing the improvement. I previously owned a SDS100 so I will be able to tell any changes. I traded the sds100 for a sds200.
mikec10
Schenectady NY
I rec'd my SDS150 yesterday and set it up to match my SDS200. I am very pleased with the results. I previously owned a SDS100 and the 150 is an improvement on most aspects. For me it was an expensive improvement, but I am happy. One issue was the programing cable has 2 c type connectors, and my computer does not have the correct connection. I happened to have a similar type of cable that worked. I did order a correct cable from Scanner Master and it is shipped today. Just a warning if you are going to order a sds150 to check your computer to see if it accepts a C type connector.
werinshades
Chicago , IL
Did you check Amazon? Anker 2 pack USB-C to USB-A for $8.
mikec10
Schenectady NY
I did check amazon. I went with Scanner Master because for this I did not want a aftermarket or third-party cable. I know I paid extra but I just felt more comfortable with Scanner Master. Delt with them in the past so I KNOW their product is good.
werinshades
Chicago , IL
No problem with Anker and arrived the same day. I’ve been using it since i owned the 150 for the past 7 months, updated programming and firmware. We’ve posted a few times on the USB-C needed, and like you my computer takes the USB-A. @jasonhouk is a beta tester, and trust his opinion and purchased it.
