Broadcastify app
jnvc57
Auburn, CA
I accidentally deleted the Broadcastify app from my iPhone, went to reinstall it and it won't show in the iTune/Apple store? Suggestions?
IcomIcR20
The Broadcastify app no longer exists. You will need to use a browser or a third-party app such as Scanner Radio.
jnvc57
Auburn, CA
Thanks, I was thinking that might be the case, Dang. Wish I hadn't accidently deleted it.
jnvc57
Auburn, CA
Ok its called "Scanner Radio in the app store? I'll try that. thanks.
Deziel0495
PEI
Paid for Scanner Radio Pro years ago! Absolutely worth it, especially as a feed provider.
It has been mentioned in a few other threads but just note that the Pro app has been discontinued, and pro features have been merged into the regular app. Regular app is many updates ahead of pro, including support for Broadcastify Calls.
KD0FEO
Wright County, MN
Minnesota
Does that mean I'll get ad's if I switch off of my current version even though I paid for pro? The regular app was updated 7/22/25 and the pro version I'm using was updated 10/11/24, I did not realize I was so far behind? How did I miss this?
AB5ID
Lee's Summit, MO (Kansas City)
The audio streaming ads are coming from Broadcastify. If you log in to Scanner Radio using your RadioReference premium subscriber credentials, my understanding is that you will no longer hear audio ads when you start listening to a stream.
Deziel0495
PEI
I don't have ads on mine and I had pro before too so I'm assuming it may carry over if you use the same app store account, but I cannot be certain that's how it works.
Gypsy51
What is the regular app? I liked the pro app for the archives, but guess i can go online to get those if I use scanner radio?
Deziel0495
PEI
Previously the free version was called "ScannerRadio" and the paid version was "ScannerRadio Pro". There's just the 1 app now, and the Pro features have been merged in. http://scannerradio.app
avery_k
Broadcastify Feed Provider, Lake County, OR
Lake County, Oregon
In the new app, you can access the archives by navigating to the stream you want the archives from, press & hold, and in the menu that pops up, select Audio Archive. Then select the 30 minute slice you want to listen to.
AB5ID
I have not been able to access the archives since I started using the new app. I currently have both Scanner Radio Pro and Scanner Radio installed on my Android phone. I am logged into both, but I only see the archives in the Pro version. I have tried reinstalling the new app, but the archives still do not appear. I really like the "calls" and "clips" feature in the new version.
