SDS100/SDS200: Broken battery door clip due to large battery tightness
rcool101
Eastern Ohio
I've been using Clip #3 with a new battery cover and it is 75% better. I took original cover and pulled bottom foam piece out since it's out of warranty. It's even better with less pressure. I shook it to see if it would lose power and it's fine. Glue is good as it didn't come out 100% but I doubt the little bit remaining is even touching
My 3rd clip broke last week. This one broke close to the end. The other 2 broke at the seam. And yes I hold the door tight opening and closing as I have always done.......
It didn't make a difference. I'm still using the cover with the foam removed and clip #4. I have 7 more clips. I'll try one of Jon's soon. They look nice
bravo14
Polk County FL
Don’t need to make it too loose like @jonwienke stated. Plus the battery will move around and possible lose power and shuts off radio. I put the new clip in and so far so good.
RRR
OFFLINE
USA
Received replacement battery door clips from Jon today, -Wow! Much better than original
KevinC
The big K
Super Moderator
1 point
Interesting event today. Left the SDS100 in the vehicle all day, came back about 8 hours later, picked it up and the battery cover fell off. Looking at the clip I got from @jonwienke and noticed it was bent out, taking the tension off of the cover.
I've left it in the vehicle numerous times in a lot hotter temps (it was only in the low 80's today) with no bending of the factory clip. And yes, I know it can get hotter inside the vehicle than it is outside the vehicle, but the factory clip never did this.
Just a heads up for anyone with one of these clips.
jonwienke
More Info Coming Soon!
VA
Well phooey. I guess I need to look into a different material if the heat of a car can do that. PM me and I'll send you a clip made from a different material. It's translucent, but prints at a higher temperature. I'd be curious if it handles the heat better.
p19997
Show Low, AZ
In the Phoenix area car interiors can arise to 160 degrees in the summer. However, people would be very unwise to leave a scanner in their car, especially if it is exposed to sunlight.
radio3353
What are the thermal specs of the materials you are using?
jonwienke
VA
The original filament melts at about 170C and prints best at 185C. Specs don't have a detailed temp/stiffness curve that would predict creep at say 60C, so I'm kind of on my own with this. The test piece is from some clear/translucent stuff that prints at about 230C. I just got a roll of a third material that prints at about 250C, and is advertised to be stiffer at elevated temperatures. So I'll be testing that as well.
radio3353
The post-printing thermal specs is what I was most interested in. It is a shame the vendor doesn't provide that data as it seems rather important in determining performance and suitability of use of the material in hot and cold environments, even for consumer use. Oh well, good luck.
jonwienke
VA
Yeah, it's not available, so you kind of have to take your chances when you buy it, and test as best you can.
jonwienke
VA
LOL. I'm going to have to be a bit more low-budget, like printing a hook and submerging it in boiling water, then applying a load.
jonwienke
VA
Every 3D printer displays Centigrade, and the filament manufacturers do likewise for temperature specs.
  • Haha
Reactions: RRR
KevinC
The big K
Super Moderator
1 point
I'm testing a prototype Jon sent me. As luck would have it it hasn't been real warm since I received it so I can't tell if it will behave differently or not yet.
In all fairness to the original clip of Jon's, I tried to break it (since it was bent anyway) and couldn't*. So strength-wise it's good, just keep it out of the heat and you'll probably have no issues.
* I imagine if I tried hard enough it would break, but just using normal old man hand pressure it didn't even flex. :p
buddrousa
Thanks for the update Kevin I have 2 1 for each 100 not going to use them until I have to. Both of my 100's are early 1st runs and are still holding up even after I started using external charges and spare batteries.
522
Murray, Utah
Just bought one from jonwienke last night, and he already had a label printed first thing this morning! My current original latch is fine, but will be happy to have this upgrade.
jonwienke
VA
I did some destructive testing before offering them for sale and broke a couple, but I had to put them in a vise so I could torque on them with both hands. And it still wasn't easy. At normal room temps the stuff is quite tough.
