BURLINGTON COUNTY TRUNKED SYSTEM
Joseph11
You don't need to put it in any specific place. All you need to do is open it in Win96.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Is your file Burlington.p96? If not, you need to rename it as such. Click yes on any rename warning if it pops up. Then open the file in Win96.
You can place it anywhere you want, usually in the Win96 folder with p96 files.
SM166
formally ny/nj metro
Burlington P96 files
there is no need to convert the file of a P96 file to a text - I tried to download your text file - remaned it severAL ways it dont work de code right
please just upload as a P96 file
please frank.......please
lbitp37
LBI, Nj
I ditto that request.
I can not down load it.
A msg. states that the file was not decoded properly as an e-mail or attachment.
Thanks Don
fmon
Eclipse, Virginia
Hey guys it can't be uploaded as p96.
Download Burlington.p96.txt (notice the period (.) between 6 and t.
Do not try to open the file. Instead right click, rename, then backspace through .txt including the period (.) between 6 and t. You will end up with Burlington.p96. Then open Win96 and click on file then select the file. Or alternately, right click on Burlington.p96 and select open with Win96 Scanner Utility.
lbitp37
LBI, Nj
THER MUST BE A REAL SCREW-UP HERE!.
i HAVE SPENT A LOT O TIME TRYING TO DOWN LOAD THE FILE ( WITH NO SUCESS)
there must be a better way.
NEED HELP.
fmon
Eclipse, Virginia
Hmmm, I've never had a screw-up downloading the file. However, if you have unzipping software, try this zip.
MSRESCUE108
having same problems
would like to just program & be done but not working properly, if someone has setup done could you please email to me, i have pro 2096 & win96 programbut i cant figure out what i
did wrong
