butel software is out now free trial it work good
I can't duplicate the start up key issue, when I select startups in the upload window they show up in the scanner, is it possible you have several favorite files with the same name?
Gommert
Butel Software
First update to the new build 3, if it still shows this problem then I need more detailed steps how to duplicate.
There was an issue in the previous build when switching between department and system settings.
Gommert
Butel Software
I will note that the program still enables all Start Up Keys when I upload a new or updated FL. It's a minor annoyance, but it's still an annoyance that I hope Gommert can duplicate and then fix.
I've been looking at the Quick Key Manager (and Overview). My two cents (and realizing different folks can have different preferences) is this:
The ARC XT has a tab on the very top row for Quick Keys. So as to make the ARC 536 and ARC XT consistent, perhaps ARC 536 could have a Quick Key Tab which contains the Quick Key Manager and Quick Key Overview.
This might be impossible given the scanner's different memory architecture, but the Quick Key Manager only deals with those associated with the active Favorites List in the brower and then just system and department quick keys. It would be nice if one could manage the Favorites Lists Quick Keys in the scanner in the same session (as well as all system and department quick keys).
Can you send the steps to duplicate this? Also in your previous message you wrote you did not connect the scanner yet? You need a scanner attached to upload startup keys.
Gommert
Butel Software
Disable the option 'Enable Quick Keys/Service Type' , it overrules the custom Startup key settings.
Also I would not enable location control if there is no GPS connected.
Gommert
Butel Software
Gommert
Butel Software
