Buying a Sds200
Carbuff
Warren County Illinois
I'm planning on getting a sds200 when they are available again and I'm thinking about a ups battery backup for when the power goes out was wondering what size of ups I would need.
jonwienke
More Info Coming Soon!
VA
A SDS200 doesn't draw all that much power, less than 10 watts. The idle power consumption of most UPS units is more than that.
N9JIG
Sheriff
Moderator
Far NW Valley
I ran a 536 on a sealed lead-acid alarm battery for days on a single charge. These are commonly available at Amazon, Batteries Plus and other suppliers.
There are outfits that sell these with nylon pouches, a cigar lighter plug and charger. I had one of these before I moved and it too ran the 536 for days. The current draw of an SDS200 is probably a little higher but still should work fine with one of these.
The problem with using a UPS is that it is much less efficient as it has to convert the 12VDC to 120 AC and then you convert it back down to 12VDC with the AC adapter. It would last a lot longer if you removed the sealed L-A battery and rad the radio directly on that. In addition my UPS's have an annoying beep when on battery power, I suppose there is a way to disable that though.
iMONITOR
Silent Key
S.E. Michigan
I used to stick a piece of electrical tape over the opening on the beeper component, or a small dab of silicon rubber in it. You could still hear it which I wanted to do, but it was no longer annoying.
TailGator911
Silent Key/KF4ANC
Fairborn, OH
I cast my vote for the Tripp Lite 1500 which serves me well during power outtages. I have 2 of them, one for my desktop computer and 2 scanners and one for my 2m/dmr and MFJ power supply. For continuous power I have a Honda EU3000iS that I bought for the RV that pulls double duty at home if and when I need it. I was in the beginning stages of acquiring what I needed to build a permanent solar power system for my shack when covid derailed me last year and I was forced to put it on a shelf until later. The plan is still a go when I am up to it.
iMONITOR
Silent Key
S.E. Michigan
Sounds like a fun project. Hope you fully recover soon!
