C4FM decoding
baybum
Howard County
Is there a Windows program out there that will decode C4FM? Without an SDR.
I want to connect the audio output of my scanner to the laptop.
I have searched but cannot find one.
G0NMY
Stoke on Trent
  • DSD+ / DSD+ Fastlane: A widely used, robust digital decoder for Windows that supports various digital modes, including C4FM.
  • DSD-FME (Digital Speech Decoder - Florida Man Edition): A popular Linux-based fork of DSD that excels at decoding C4FM, DMR, and P25.
  • SDRangel: A comprehensive SDR software that includes built-in demodulators for C4FM, D-Star, and DMR, eliminating the need to pipe audio to a separate decoder.
  • OP25: A GNU Radio-based tool that handles C4FM modulation and YSF voice protocols.
  • Multipsk: A multi-mode software that can demodulate C4FM (voice and data).
  • SDRTrunk: Primarily for trunked radio, it supports decoding C4FM and CQPSK LSM Simulcast.
    Hope that helps
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Speaker level? Probably not. But DSD+ will work with a discriminator tapped scanner.
baybum
Howard County
Ok, which one of those will work with windows using the speaker or audio output of the scanner? I don't know how to do discriminator tap.
wgbecks
NE Wisconsin
It's not likely any of them will work with speaker audio. Get an SDR, they are cheap and work well.
  • Like
Reactions: wtp
baybum
Howard County
I know, i have one. But wanted to use this option instead. If there isn't one out there for sure, it is what it is.
baybum
Howard County
Copy that. I did find an APRS program that works. Not much excitement there. I'm a ham 30 years, just now playing with digital since im retired.
MaineGuy
Still figuring stuff out...
Central Maine
I've had good luck with SDRTrunk and a pair of cheap USB Tuners - RTL-SDR Blog V4. Just one worked pretty well.
Not too awful to set up.
For a few dollars more the Airspy devices are significantly better.
Might be cheaper and easier than installing the tap on your scanner.
boatbod
Talbot Co, MD
I believe op25 can do c4fm it from mic input, but I will say that is old and seldom-used code for analog input. Frankly for $35 you can buy a cheap RTL dongle and save yourself some headaches.
baybum
Howard County
I have a SDR. I havent used it, i know i can, and learn it. But i wanted to find a windows program. Personal preference. Like i said before. If there isnt one...it is what it is. Part of doing different things in the hobby.
redbeard
OH, PA, WV Regional Admin
BEE00.348-3.1
These programs need unfiltered raw audio and a speaker output has too much passband filtering and de-emphasis to allow the digital waveforms to pass without distortion. So that's why you need a discriminator tapped scanner. 15 years ago this would have been the way to decode DMR before it finally came to scanners.
If you have a ham rig with a 9600 baud output, that will work in lieu of a scanner with a tap. But as everyone else has said, there isn't much reason to go through this pain anymore when you could be online and decoding with an SDR stick in a few clicks.
Forts
Ontario, Canada
Many of the programs listed above are Windows based... DSDPlus, Unitrunker, SDR#, SDR++, SDR Console, DSD-FME, SDRTrunk and others will all run natively on Windows.
dlwtrunked
If it were possible, there would be such a program and it would be popular. There is not. There's your answer.
