Cable Question (SDS 200)
BOBRR
Boston, MA
Hello,
Haven't used the radio (SDS 200) in a long time due to medical issues, but have
fired it up again. Trying to neaten up all the cables and wiring.
Worried about breaking the radio's connector, so thought I'd better ask you folks first.
On the front panel, bottom-right:
My question relates to the rectangular connector that is above the phone jack connector:
I can't pull it out (safely)
There is a "bump on the top of the cable's connector where it plugs in.
I tried pushing, and moving it to dis-engage/unlock, but no luck.
Anyone know the right "movement" on this "bump" that would allow easy pulling out of the connector.
The cable is likely mine from years ago, and not Uniden's, but am hoping someone might be using a similar one.
Thanks,
Bob
TexTAC
If you are talking about the LAN connector, you should squeeze that “bump” down while pulling the connector out.
