California Radio Interoperable System (CRIS)
WirelessMike
Looks like the Town of Mammoth Lakes is planning to join CRIS with additional sites at Lincoln Mountain and MLFPD Station #1
It looks like the Mammoth Lakes FS1 site is on the air with 151.1000 as the current control channel. Callsign is WRZR827.
151.1000 Control on air now
155.1675 Listed as Control
155.7225
156.105
I have not logged any actual traffic, yet. More details as I figure them out.
officer_415
SF Bay Area
155.7225
156.105
We’ll need the site number in order to add it to the database. The NAC and neighbors would be great too.
WirelessMike
The NAC is 9D9. No traffic is transmitted, only PDU, TDU, and TSDU packets are sent. I have monitor but not seen any site ID or other network info transmitted.
I am thinking that the transmitter is hooked up and being burned in, but not connected to a controller or network, so in the very early stages if it install.
I am using DSDplus public. Any suggestions to sniff more out of thus site?
officer_415
SF Bay Area
There must be a site number. Are you able to post a screenshot of what DSD+ is showing?
WirelessMike
DSDPlus v1.101 and v1.074. -v4 logging. Only shows NAC, TDU, and TSDU packets and no site info.
Funny thing is 151.100 is in-between two Mono County Mutual Aid repepeaters: 151.085 and 151.115. Both are carrier squelch. A low power transmitter in the middle of nowhere (RF wise, I love Mammoth Lakes ;-) and they picked THIS frequency!
officer_415
SF Bay Area
Hmm...I guess keep us updated when a site number pops up. Thanks
WirelessMike
Yeah, it sure looks like they installed the TX and antennas and tuned them up and burning them in now. Likely now waiting for Telcom vendor vendor to deliver the needed circuits for the trunk controllers. I would not be surprised if the TX is currently configured as a conventional P25 repeater, with a data channel, or as a single site trunked system, but even that would have a site number.
I have heard nothing on the other frequencies on that license.
Anyone know if the TX or the controller generates the TSU and TDSU packets?
Can anyone recommend a better control channel logger that is Win10 freeware?
Sorry, but I am just passing thru, so no more updates. I just wanted to update folks to keep an eye on this site.
inigo88
California DB Admin
San Diego, CA
I have heard P25 conventional and trunked repeaters broadcasting continuous data that sounds like a control channel but doesn’t decode used for coverage testing before. I forget the official name for this function but once coverage testing is complete they replace the test channel with a control channel (if the system is trunked). That may be what you were hearing, but the free version of DSD+ is also quite out of date, so like others have said recommend upgrading to DSD+ fastlane to be sure.
INDY72
Indianapolis, IN
On Motorola wide area P25 TRS, we have seen subzones turned on with just a carrier signal beacon that doesn't have any "useful" data for a period of time. Then suddenly each site has an actual control set up and we log site id, and sysid.... Then bam the subzone goes live with full data. (MSWIN, Entergy, SAFE-T, I have seen this on, with SAFE-T, and Entergy being upgrades from ASTRO Smartzones to ASTRO-25. MSWIN was a whole new set up from ground up.) Also noted this on the growing Duke Energy system. Sites beacon, then go live, then go TDMA CC.
WayneH
Forums Veteran
Super Moderator
Your master site
The data carrier you guys are describing is a test pattern. It's the payload within the P25 CAI format and it will use what the repeater is programmed for in its header data (the CAI), which would be the ACI (NAC in trunking terms). There are different test patterns that can be used for bit error testing. So basically you take a channel out of service (from the system's perspective), put the individual channel(s) into service mode and enable the test pattern. You can use an analyzer or coverage testing software (Motorola has their own internal software for this) to determine your bit error rate for the location you are in. None of this has any bearing on the control channel since as far as it knows, the channel is out of service (and in this case under local control).
It is in no way a conventional channel.
Teotwaki
SoCal
Thanks! Interesting facts and observations.
Jim
mcjones2013
Radio Communications Enthusiast
Sacramento, CA
I've been keeping an instance of DSDPlus running on Site 1 (Pine Hill) for the past couple weeks. These are the talk groups I've logged (some only have radios joining, but not talking).
That 7xx range is CHP. 790 and 793 were active today, encrypted, so I'm thinking they're getting ready to turn on another channel soon.
1143 is also CHP-related I believe, there's some occasional encrypted traffic with CHP radios on that channel, with the same radio IDs then going to the main dispatch channels other times.
22
125
130
131, PSC Area 01
133, PSC Area 03
134, PSC Area 04
137, PSC Area 07
139, PSC Area 09
143, PSC Area 33
145
150
151
154
200
202
215
217
427
438
439
735
748, CHP Valley Gold
749, CHP Gold Tac A
750, CHP NSA Ch 3
751
752
753, CHP Valley Black
754
755
756
757
758
759
760
761
762
763
764, CHP Valley Green
765
766, CHP AUB Ch 3
767, CHP GVY Ch 3
768, CHP PLC Ch 3
769
770
772
773
774
775
776
777
778
779
780
781
782
783
784
785
786
787
788
789
790
791
792
793
794
795
1142
1143
1420
1601
1623
1636
1637
1642
1643
1909
1939, FTB Security
1940
2043
2063
8016
8021
8022
8100
8131
8142
8143
10001
10005
50001, LAW1CA
50011, FIRE1CA
50012, FIRE2CA
50021, EM1CA
50031, MA1CA
50032, MA2CA
50101
50151
50153
50251
50301
50351
50383
ccsochp11
SACRAMENTO
I heard a radio tech on lowband black say he was going over to the black Tac channel a few days back and when I checked unitrunker it was talkgroup 790.
ogppc
Merced County CA (West)
Request for a little help understanding what I'm seeing or where to look in my fastlane logging.
Ive been monitoring Mt. Oso for quite a while and can see the tdma chatter for the encrypted CHP groups. In my channel window I've also logged 12 tightly packed frequencies in the 800mhz band. 851.0325 to 851.17500.
Where can I go within the logs to try to understand what is happening with these frequencies and/or what they are being used for or am I wasting my time?
