Monitor this DMR Motorola Connect Plus (TRBO) system: New Hampshire Electric Cooperative Trunking System, Various, Multi-State - Scanner Frequencies
Thanks,
rja1
Thanks,
rja1
whistlergroup.com
whistlergroup.com
The GRE/Whistler scanners do not trunk track DMR systems, they merely scan through the frequencies looking for activity that matches whatever talkgroups you have programmed. I don't see any reason why the scanner wouldn't decode voice traffic on that system.Monitor this DMR Motorola Connect Plus (TRBO) system: New Hampshire Electric Cooperative Trunking System, Various, Multi-State - Scanner Frequencies
Thanks,
rja1
Does anyone actually take the time to read posts anymore? He wasn't asking HOW to upgrade, he was asking if the scanner will decode a particular system AFTER the upgrade.
As GTR has already mentioned, there are several versions of trunked DMR systems, but that does not matter due to the way that Whistler scanners handle DMR. While they do not actually track the systems (unlike Uniden scanners), they can monitor for the talkgroups you program, or for any activity where a wild card is in place. Unless your target system is very busy, the method Whistler uses for these systems may well be sufficient to meet your needs.It's already been upgraded. I'm a DMR virgin & I have NEVER programmed a DMR system. Does DMR come in two flavors (like P25), trunked & conventional? Can the upgrade monitor both flavors? Can DMR be LSM?
rja1
