Can an agency see if you read the code plug off a radio?
wa8pyr
Lead Database Admin
Ohio
This is true of the PRC153 (XTS2500) that has Tactical Inhibit enabled and is written with an ACK. If you even read those radios and you do not have the original iButton ACK that was used to program the radio, the radio will be "killed." This happens all the time, because service member's don't realize that the radios were written with an ACK or they have no idea what happened to that iButton. It can be undone with unmentionable software, but it still erases the data in the codeplug.
Don’t you mean “ASK” (Advanced System Key)?
rescue161
KE4FHH
Hubert, NC
I have several PRC-153s and just read and program with Astro CPS, never had a problem.
That is because those particular 153's were never programmed with an ACK, nor did they have Tactical Inhibit enabled in the codeplug. I guarantee that if those two elements were satisfied that you'd have a brick on your hands.
rescue161
KE4FHH
Hubert, NC
No. ACK was Advanced Conventional Key and was used by the military for the 153's with Tactical Inhibit to make sure the enemy never would be able to read the radios if they were ever captured. See the pic that I attached in my post. It references the ACK.
wa8pyr
Lead Database Admin
Ohio
Ok, didn’t know that. I only dealt with the XTS from the civilian trunked side, never saw reference to the ACK.
