Baofeng Can BTECH UV-25x2 run on a simple power adapter?
jnojr
Chandler, AZ
Right now, I'm using a BTECH power supply. But I want to replace it with a UV-50x2 (which I'm certain does need the PS!) and use the 25 somewhere else, hopefully without a $100 power supply.
rf_patriot200
Freeport, Illinois
Because of the current is draws on transmit, Yes yow will need a dedicated power supply ... UNLESS you don't plan on transmitting and just listening, then maybe a Wall wart might do it, but I really suggest a PS or at least a small 6amp or 12 amp battery.
