BCD436HP/BCD536HP: Can't update firmware
dmchalmers
hooked up to laptop in sentinel update firmware nothing shows that its connected bcd 436? doesn't seem to update data base either. Piece of Junk like i'm thinking?
phask
zanesville
One sentence to rule them all.
Slow down, and take the time to explain in detail what you are doing and what is it "not doing". Sounds like the piece of junk is behind the keyboard.
eaf1956
Evansville, IN
Obviously the 436 is a piece of junk and needs to be disposed of properly. Feel free to ship it to me to rid you of all the misery it’s causing you.
OK I usually don't but send the junk to me and I'll dispose of it. Scanners don't work in MI. lol
nessnet
What month is it?
In 95% of the cases it is 'operator error'....
Just sayin'...
Of course, there is always the possibility of equipment failure, but as everyone else above already said... chill and take a step back, I'll bet you figure it out.
Use this forum as a resource - lots of very knowledgable people here.
Very hard to stump us...
nessnet
What month is it?
Most all tech is a 'chain'.
Meaning, there is a chain of various components that all work together to make something work.
The radio, the SD card, the cable, the computer - YOU also.
All need to function to work correctly, (including you with setting everything correctly).
One does not work correctly, it all does not work.
Troubleshooting is a simple process of elimination.....
rks1257
Did you do the Sentinel computer update first before trying. There was a major update about a month back that must be done before downloading the frequency update.
yeah this happens scanner should be in USB storage mode then the software should see it try this use the software that came on the SD card OR an OLDER version of Sentinel
Ubbe
Stockholm, Sweden
A computer sees the 436 as USB memory device and the 436 should respond with a message on its display if you would like to use mass storage mode or data mode. It could be the USB mini cable that are only done for charging and not for data.
To avoid that kind of issues you can get a $4 SD card interface and remove the SD card from the scanner and try directly on the computer. When and if that works you can try and look at the cable as that has to be the problem or the scanner are actually faulty. But instead of having it repaired for $90 you can use that $3 interface.
/Ubbe
