I am not sure I titled this thread correctly. Currently own a PSR800. Will the information that I have on my MicroSD card be compatible using the new EZScan software for the TRX-1? Would save a ton of work if it was.
Thanks Don! So does that file need to be manually deleted, or will the software overwrite it with the compatible version?
If you're copying data between scanner models, you won't want to copy that file. The target scanner will happily use data that has either changed meaning or default value. This is why people see "weird" signal bars after they copy their PSR-800 CDAT file to a WS1080.
I copy files between scanners all the time. I just leave the .GLB file alone. Don't delete it. Don't copy it.
So, (without knowing this), I copied my PSR-800 file to my brand new WS 1088 and now the "S" signal bar doesn't display any bars -- just "S". Can this be corrected? Please advise and thanks!
You can do a Restore Factory Defaults .. or just delete the file and restart the EZ Scan program.
Please clarify -- If I did a restore factory defaults would that mean it would delete all the information I've copied into the scanner and then I would have to re-enter it, or is there just one area I could restore?
jimg this is what you should do.
1. Save your EZScan 800 configuration to Archive.
2. Open EZScan 1080
3. Do a Restore from Archive and restore the zip file created in EZScan 800
4. In EZScan 1080 on General Settings Tab click on Restore Factory Defaults.
5. Then set each of your settings in EZScan to what you want
6. Lastly copy your Configuration from EZScan 1080 to your 1080 Scanner and you should be fine.
jimg;2635664 Where can I load the EZScan 1080 said:If you cannot find the EZScan Software for the 1080/1088 on your card you can download it here.
https://whistlergroup.com/pages/ws1088-downloads
DO NOTUSE EZSCAN 800 ON YOUR 1080/1088 SCANNER.
2. Open EZScan 1080
