audiointercom
- Joined
- Jun 2, 2016
- Messages
- 1
Hello,
I am trying to program a CDM 1250 mounted in a Riedel Riface using the HVN9025. This unit will be using frequencies legally given to me for use on a major TV broadcast. The Riface is fairly secondary to me at this point as i need to program the 1250 and the Riface is working as it should. I am running Windows 8.1, using port 3(I have tried all high and low ports on this computer). I am running the HVN 9025 software but have also tried MOTOTRBO(obviously nothing will happen there).
I'll go ahead and give a brief synopsis of what I have already done troubleshooting wise from searching and scouring these forums as well as batpatrol. I have downloaded the prolific driver(the up to date driver as well as trying to revert back to an older version). I have used a series of cables including rib and ribless, as well as every port high and low that i have available on this computer(as stated i settled on 3 as 2-4 seem to be recommended most by other forum users).
Right now I continuously get the error message "Couldn't open port. Check whether device/RIB are powered on or not, and the Device to RIB, and the RIB to PC connection is OK." I am not using the read button, I have been going through File> Read Device and when the pop up to select port comes up only the port in which i am plugged into is shown.
