CDM 1250ing sense issue
Mtnrider
Greene County New Yawk
Have a CDM 1250 that worked without the ing sense and someone decided to check the program to see what was up....changed the program. Now radio wont power up . Anyway to get it to power up and go back to turning it on each time....the way it was....ill assume the ing sense was not working to start with.
wa6lif
hoisington KS
ignition sense
Looks like you might just be one of the unfortunate few that got caught in the broken ignition sense problem. There have been others posts on here a while back warning to not program your radio to follow ignition mode if you find that it doesn't work in the ignition OR main power on mode. While I don't have the same exact problem you are dealing with, I do have a couple of CDM radios that the ignition sense lead to pin 10 does not function even with proper programming.
Mtnrider
No it did not work with the Ing sense.....But radio was programmed not to follow "ing sense'
.....someone decided to tweek things to get it to work....ahhhh....nope ....now it wont go on. Radio worked stellar by turning it on each time prior to said tweek
KG7TTY
I'd be curious what the radio shop said. Might be cheaper to get another radio and move your codeplug to it.
