CDM1550LS Display Problem
JoshuaHufford
Jefferson City, Mo
Today the display on my CDM1550LS stoped working properly. I removed the front panel re-seated both ends of the ribbon cable with no change.
Any suggestions?83594
You may have to remove the circuit board and clean the contacts where the LCD panel sits. Looks like it's got some crud on them, or it's not seated properly.
Giddyuptd
Here and there
Could be the ribbon where it goes into the LCD. The MTS line use to do that and some fabricated tricks to make it come back alive though it was a all or nothing and a slip up could make it worse and some didnt last. There is posts out there on web about that.
If it isnt the ribbon going into the LCD where the adhesive has worn and come up then it is dead pixels.
Probably be able to find a new LCD and ribbon or head on the infamous auction site or classifieds here.
I'd try what Mmc suggests and if that dont work it's one of the above.
And if not, you can find used CDM's on eBay cheap.
Or, try WisComm.com, they seem to still have a lot of parts for these radios.
