CDM1550LS
Rudy3145
New York
Trying to program CDM1550LS with conventional analog UHF.
I can read the radio ok but I can't write to it.
I get a message about narrowbanding regulation (all my freqs are 12.5) and the message says to contact Motorola to request a 20/25Khz enablement key should this application be needed to support deployments outside the US.. Again, all my freqs are narrowband.
The second message that pops up when I try to write is CPS operation on this device failed - refer to read me file for possible reasons.
Any thoughts?
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Any thoughts?
For the first issue make sure to delete any LTR/Passport systems.
Rudy3145
New York
Just did. Fixed that issue. Now it said it cant convert image to codeplug...
Never had this issue before
n3obl
ØAES-1024
PA
If you are using 6.12.09 then you need a wideband key for certain freqs in wideband. You can use 6.12.05 on that radio with no issue.
Rudy3145
New York
Failed to convert database into codeplug image is message I'm now getting. I have no wideband freqs.
Using 6.12.09
Rudy3145
New York
None of my frequencies are 25 wideband, they're all 12.5 narrowband.
Strange
Jtaub
Any thoughts?
Reach out to me privately and I will see if I can help
