I'm hearing lot's of "check 1-2-3"'s on the air right now on Pat Ferg PD 1 user id 7702
You may need to turn your attenuator on if the signal is too strong from the PSU Ford Building transmitter. Audio on my GRE PSR-500 is great and I can even pick up the system in Mifflintown, Juniata County. Don't set your squelch too high and check your attenuator in case your front end is being overloaded.
I did some digging around and found a reference that said to check the signal quality of the system - mine shows 40-60% which is below what's needed for good decoding. I will probably need to get a better antenna/move the scanner to another location.
Brett, do you perhaps have a cell phone tower nearby? In my experience, cell towers cause a great deal of interference with reception of control channel data on scanners. The signal strength display may appear full strength, but the cell signal may cause interference of the received data causing poor signal quality.
