CFB Borden
rfsparkz
Angus Ontario
Hello,
Does anyone have updated frequencies for CFB Borden.I entered 2 different sets found in the forum as well as direct download using the software for the BCD396T but they dont work.I can pick up the base by directly entering 148.300 & 148.960 fm .Any help appreciated.I am close enough to hear artillery at the base and wave to the helicopters when they fly over head.
Yours Russ VE3ELL
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Mine work and should be the same as the database:
150.245
150.710
149.635
151.880
148.195
148.300
148.960
Bandplan 1
Base 148.160
Step 15
Offset 380
Bandplan 2
Base 150.245
Step 15
Offset 487
Bandplan 3
Empty.
rfsparkz
Angus Ontario
The system now works using the frequencies you listed.When I use ARC396 and downloaded the first time I find that the database is missing 148.195, 148.30, 148.96. Perhaps the site owner can update this so when you download this system it works.The frequencies 148.30 and 148.96 are used a lot.I am located close enough I can pick up the base with just the rubber duck antenna.
Thanks Russ
