Has anyone else had an issue with this? The problem started yesterday, my channel hold soft key has been intermittently responsive. All of the other keys including system and department soft keys working as normal. The physical button seems to be working fine with a solid click on press but it will not always hold or release the channel when pressed. I either have to press it much harder than normal, press and hold for 2-3 seconds, or press a few times in a row to get it to hold/release. I've tried a hard reset and no change.
Hoping this is not indicative of a larger hardware problem, possibly a side effect of the latest firmware update? Would appreciate anyone else's thoughts here.
