Chesapeake FD Automated Dispatch?
Larry51
Chesapeake, VA
For the last several weeks I’ve noticed that the Chesapeake FD apparently has been testing an automated dispatching system. It appears as “TAC 11” on my SDS100 and starts with a new two-tone alert followed by the assignment announced by a voice that’s a bad imitation of Alexa and which mispronounces many of the street names.
The test broadcast is followed immediately by the regular dispatch over on the usual FD/EMS Dispatch channel.
The list of CFD talk groups in the Radio Reference database doesn’t show a TAC 11 but does show a channel called “CFD Disp 2 Dispatch 2 (automated).
Does anyone have any details as to what’s going on?
Randy_Vick
Suffolk, VA
Two weeks ago while traveling I heard the automated, but not the "regular" dispatch for fire.
Webodisk
Silent key.
Virginia Beach,VA
Yes true, they are doing BOTH automated broadcasts first, then Disp 1 with a human rebroadcast. A few cities are doing this, Tac 11 was changed
clbsquared
Isle of Wight County
Chesapeake has entered into an Auto Aid agreement with Suffolk. Right now it's mostly for structure fires, commercial fires. Anything close to Chesapeake and Suffolk is auto dispatched and vice versa. Also, Suffolk changed their talkgroup names. To my knowledge, there will no longer be a "Fire 2, 3, 4, 5" etc. They're all TAC channels.
Randy_Vick
Suffolk, VA
I heard the automated broadcasts, followed by the human rebroadcast today. Automated included district, human did not. Human had significantly additional detail.
At about 1330 Chesapeake was dispatched to an MVA on 664. SFR was dispatched for "mutual aid" and "auto aid," but there was a significant time delay. Chesapeake responders had already requested and dispatched additional ambulances before SFR dispatch occurred.
clbsquared
They're still working the bugs out of it. They just brought it online last week.
K3QQN
Virginia Beach, VA 23452
I have heard the same thing. I live in the Beach, but hear their system automated alerts too. Usually I'm driving, but it's similar to what we have on the Virginia Beach system. Apparently it doesn't do well with abbreviations and does not learn local pronunciation. The IT guys reprogramed ours to change how the mutation occurs a little so the abbreviation "AVE" is better understood. Hampton and Norfolk have done the same thing. It's really for station alerting. It replaces the old Motorola tones that tripped the pagers and house klaxon or bells. Somehow a study was done that says the old, loud wake up system was hazardous to responders. They said it causes tachycardia and a nervous reaction that is potentially harmful physically and mentally. They think a softer house alarm is better for the nerves. So, you hear several tones, see a printout on the enunciator, and hear the voice alert. If you're on the road, you have to listen to the radio command channel though. I'm an old volunteer and I can vouch for the klaxon blowing you out of bed at the station or the pager waking you up at home. With the new system, we can't take Zone Medic units home anymore, and if you turn the portable down too far, you miss the call. But, if it saves someone from stroking out late one night, then I guess it's ok. By the way, I am sure this is a permanent change, with their radio maintenance doing some fine tuning. The duty crews at our station hate my pager reception on the talkgroup because it's not station limited. So, I generally lock it out if I'm there. Regards, K3QQN
gosharks
Unrelated but related: does anyone know when Chesapeake Station 10 is opening and Ladder 12 is moving? It is way behind the scheduled opening that the City had announced.
LeSueurC
Virginia Beach, VA
Are they moving Ladder 12 or making a Ladder 10?
wa8pyr
Lead Database Admin
Ohio
Assuming they're using Locution (which seems to be the hot ticket for semi-automated dispatching right now), it's not only for the "kinder, gentler" wake-up. The primary reason they started using it here in Columbus, OH was to speed up dispatches. Because Locution is IP-based and sends dispatches to the firehouse over network lines, multiple runs can be dispatched to different houses at the same time, while it also goes out over the dispatch talkgroup. If there are multiple runs going out at the same time it might take awhile for a run to make it to the dispatch talkgroup - which inevitably leads to companies marking responding before the run goes out on the radio - but it gets there eventually; you can usually tell when this happens because Locutia (nickname for the female voice around here) will dispatch several runs in quick succession.
It also works fine with pager-based systems over the radio, although the speed aspect of sending multiple runs simultaneously is lost.
Locution also greatly improves intelligibility. Because CFD still uses firefighters as dispatchers and they rotate desks during their 24-hour shift, you would hear several different people dispatching runs in a single 8-hour period; some of them had good pronunciation and intelligibility while others were nearly unintelligible. With Locution it's always that same voice.
We had the same problems here with Locutia mispronouncing street and business names (for example "Meijer" stores were pronounced "Mee-jer"), but they eventually told her how to pronounce it correctly.
One thing Columbus FD does do is put the humans to dispatching runs several times a month just so they don't forget how. Normally the dispatcher just sits there, quickly reviews a run sent to him by a call-taker (also a firefighter) then clicks the "GO" button; from there on it's all Locutia.
I also can attest to the tachycardia issue; I was rudely awakened in the middle of the night many times back in my firefighting days. Anything that will ease that shock is a good thing, although Locutia gets pretty boring to listen to.
BoxAlarm187
Level 6 RR Member (Since 1998)
Old Dominion
WestNet and Phoenix G2 are the two systems we see throughout Virginia, but of course the idea is exactly the same. Quicker out-of-the-door times, consistency in pronunciation, and of course, the heart-saver tones. It's also nice that we can (we're using Phoenix) alert 20 individual firehouses of 20 different calls at the exact same time.
Larry51
Chesapeake, VA
I contacted the Chesapeake Fire Department and asked about the automated system. The automated computer voice is part of the Phoenix G2 system and is followed by the human dispatcher who re-transmits the assignment and communicates additional information. The Alpha/Bravo/Charlie/Delta designations are assigned to a call priority, which translates into a specific run prescription.
According to the CFD, there are no plans to replace dispatchers with computers. The new G2 system is more computerized, but only to the extent that is provides more information and notification at the user level, such as in the fire station using message boards and LED lights.
BoxAlarm187
Old Dominion
That is correct, the G2 (and similar) system doesn't replace people, it just brings automation to the process, and saves about 45 seconds of call processing time.
JimD56
KO9JAD/Retired-Fire Lieutenant/Paramedic
Davie, FL (Miami/Fort Lauderdale Metro)
We love Phoenix G2 here in Miami-Dade. Been using it for about 6 years. Totally scalable. We are the largest subscriber of the system in the USA. Only tones out the correct unit bunk rooms based on the call or all station call for full assignments.
Full App support on IOS and Android AND we even got to write our own wave files for tone outs. So obviously for structure fire assignments, we chose the old LA County Fire tone out from Emergency, yeah the TV show. Pretty geeky awesome.
K3QQN
Here in Virginia Beach, there's usually simultaneous dispatch using the automated system and dispatcher on the command talkgroup. On the auto dispatch, fire and rescue are dispatched separately since the annunciators in each station are separate. Since the automated part transmits a few seconds faster, I usually hear that on the scanner. In the station, sometimes, I'm confused by both the voices at the same time, but not saying exactly the same words simultaneously. I don't run anymore, but, even though the klaxon would certainly get the heart pumping, I found I needed that to wake me on nights, or days, I was really sleeping well. This soft wake up would not get me up and ready to go like the old system did. We have a separate, paid 911 center here. Dispatcher training is completely separate from street ops training. There are no firefighter or rescue personnel doing that, unless they are volunteer rescue. 95% of our rescue manning is volunteer here. Fire is paid. In any case, there are so many calls for service, any other type of dispatching would not likely work for us. Last year, rescue alone ran over 47000 calls. The other thing is that pagers are no longer used. If you volunteer, you have to have a personal radio, be at the station, or be in a unit to hear the call. This impacts large incident call back of off duty volunteers. The city uses group me paging on cell phones to try and overcome this issue. The time delay is greater though, and response is slower. Traffic volumn also impacts volunteer response too. Gone are the days of the red light equipped POV. It's just too dangerous and the rescue chief won't approve it's use anyway.
BoxAlarm187
Old Dominion
I haven't monitored VB in ages, but are you saying that when you're in quarters, you're hearing both the automated dispatch AND a human?
Webodisk
Silent key.
Virginia Beach,VA
The automated Dispatch is for station alerting, call goes out on Automated, then repeated based on call type on Fire command Or EMS Command, only way to hear both is to have a portable on
