What is the battery charger your using? Do you have just one battery?
I run dual batteries but am finding that my shorter drives now they are not staying topped off.
How do you handle power-down on the 536HP?
Great looking install, what were the console model numbers anyway ? I have 2015 gmc sierra with 3 radio console and have out grown it. I guess you took out your middle seat/console to get this in.
Thank you
73
Kenny
I don't. It stays in the on position and powers up and down with the rest of the console. I have no notable problems from doing this for two years. The only annoyance I have is I wish when I turned the truck back on (just leaving it off for a few minutes to get fuel) is it reboots the scanner because of the voltage drop. I'm still looking into some fixes on this though.
Great to hear, thanks. The XTLs reboot as well, though, right? Just like any car stereo does when you go from acc->start.
So I bought the same switch you did, have the chargeguard and bluesea box. I bought the version of the switch that can be surface mounted. How did you mount yours? And then how does the power cable physically go from the firewall to the switch? Not sure if I should try to flush mount the switch since then the power lead would run into the console, to the switch bolts which would be in it, but then would have to come back out of the console to the chargeguard since I want that accessible. Also what guage did you run between switch and chargeguard?
I used industrial strength double sided tape to mount the Bluesea master switch. It's affixed to the console close to the bottom where the wires come out of the console to it. Since I do not use the master switch frequently, I'm not worried about it coming loose. It's pretty snug there.
As for the power wire, I used 8 gauge wire from the battery to the master switch. I also used the 8 gauge power wire from the master switch to the ChargeGuard and from the ChargeGuard to the BlueSea fuse box. The max voltage going through there would be one XTL radio transmitting at high power and that uses an 8 gauge. It's fused at the battery with a 30 amp fuse. I have had no issues.
Is the shore line plug auto-eject on key?
Where did you source it?
