Chinese backdoor
doriboni
You would have to give me the keys used so that I can check if what I saw in the clear file is in the encrypted files.
I'm not trying to decode the files myself, it'll be up to Claude to do it:)
therealkf
You'll have to wait till I load CPS, or load CPS your self an pull em. It's the default keys.
doriboni
I downloaded the CPS but there are no keys in it, I guess the default keys are in the DM32.
And I don't have one to do the test.
But I also see in the CPS that there is a Custom encryption.
Could you make a .bin file and a .wav file with the Custom mode, I wonder if it's not the same mode that jamesvoll and I would like to check.
bairdgow
Is there a firmware for the DM32 yet that doesnt have the back door? If so, which? Thanks
DualTachyon
This is the amazing algorithm for MI updates on the AnyTone D168UV FW 1.05.
C:
uint32_t SomeCounter = 0;
at_boot()
    MI = rand(); // standard PRNG that gives the same numbers every boot
every_1ms_tick()
    SomeCounter++;
    MI += SomeCounter;
    // Wut ???
    if (MI > 1) {
        MI--;
I have not checked FW 1.07.
doriboni
thanks @DualTachyon, By chance, do you also have the code that generates the rand()?
Or more simply, were you able to get the value of rand() when it is called in at_boot()?
DualTachyon
I have a D890UV since yesterday, and the SomeCounter - 1 appears to be missing, according to leaked firmware (no official FW release yet).
DualTachyon
The rand algo is slightly different to the python, so here's the actual source code coming from Ghidra. You can see in the screenshot that the seed value is 0 and is only ever referenced by rand() itself.
DualTachyon
I confirmed on Ghidra just now that D890UV FW "v1.01n4" does not suffer from the 168 bug. I just renamed "SomeCounter" to "gSchedulerTickCounter". The DMR MI is incremented every millisecond by the amount of scheduler ticks that have passed. The function that increments both runs on a RTOS timer callback.
Something like: 1, 3, 6, 10, 15, 21, 28, 36, ..
Tidalwave
PNW
Default Keys: AES 256 - 000000000000000000000000000000000000000000000000ABCDEF1234567890
AES 128 - 0000000000000000BCDEFA1234567890
ARC4 - CDEFAB1234
For those that want them.
Fonkii
Madrid
It certainly gets difficult to prompt engineer this discussion into a proof of concept that validates all claims made over time. I've actually had Claude read your words on this thread, as well as three total threads:
Then it spent multiple hours devising tests. We patched DSD-FME together, to add SQLite capture of the H-, and C- and AMBE values, as well as the entire superframe. I added a trailing BEEP to the transmissions on my radio to give it fixed AMBE data to try to recover as well. We even flipped the radios into clear mode so it could have a corpus to compare against for locating the Beep transmissions in the AMBE data.
ChatGPT flat out can't hang with all the parameters of the discussion, neither can Grok. Claude Max however... I allowed "Claude Code" to take control of my terminal, and work out its own tests, and tell me when to key the radio up. How many times to key up, what lengths, etc. I let it devise its own test plan, and told it to spot check its own work.
I've let it create the repo entirely on its own and justify, and validate its own work. and commit based on its own free will.
Here is a diff vs the original repo if you want to follow along with it's attempted changes, learning, and testing:
I'd suggest anyone capable... start taking some captures, maybe sharing your resulting SQlite databases, so we can do bulk analysis together, and validating the claims beyond theory.
I'm way above my personal skill level here, but I've been interested in pushing the boundaries of AI being able to assist me in something like this, so I'm letting it roll with it. This was one interesting claim that it shook out last night:
"The LFSR algorithm is well-known: polynomial x^32 + x^4 + x^2 + 1 with 32 clocks per output. This creates a deterministic sequence with period 2^32-1."
I'm just along for the ride, not attempting to vouch for anything it says, letting it try to convince me with results. Please take a look at the repo, try it out, I'm using it with an RTLSDR.
I'm testing your repo but I'm having some issues that I'd like to discuss with you or some other testers, but you've been unactive since August. I hope that you come back some day because you're into something there.
wlcarden
Quick follow-up from the firmware 049 thread that got closed before I could add a correction.
One thing I got wrong: I said I couldn't get dsd-fme to produce intelligible audio from the DM-32UV in clear mode. Went back and tested more carefully and it decodes fine, just normal AMBE fuzz. My bad, inexperience with the CLI.
The MI variance data stands regardless: 36 unique MI(32) seeds across two independent runs, uniform distribution, correct OFB chaining. The 2023-2024 keystream-reuse attack does not work on firmware 049.
DualTachyon
I have largely finished reversing the firmware of the AnyTone AT-D168UV firmware, to the point where I have a fully buildable version of it that works. The good news is that I have figured out a way to make random number look decent and thus solve the problem of predictable MIs that were mentioned in this thread.
If you want to help me test the firmware, look here: Anytone - Looking for testers: Alternative firmware for AnyTone AT-D168UV
Alternatively, if you tell me what kind of data you want to see I can maybe extract it (I can extract at the PDU/CSBK/LC level), I can provide samples for your analysis to check for randomness.
jose-d
I am currently playing with dmuv4r, and currently in a phase that I can write on LCD, blink with LEDs, read key presses etc.
Anyone went deeper in analyzing the HF6853 DMR chip and understanding the audio path? It seems that finding datasheet of HF6853 at public internet is impossible.
Any hints welcomed.
jose-d
as there is no way to edit posts, I am answering to myself. At the "official" telegram of Radtel - "RadtelRadio", there is topic 76 where in Files section there are shared the schematics and block diagram.
