Well gang I'm still at a loss... for some reason I keep getting the Scan Mode Nothing to Scan screen on my 536 when trying to monitor this favorites list.... I've mad a few minor adjustments and do have the Download and Monitor settings to on. Location control turn off.... I've never programmed a digital site and it's making this ol man wanna cold beer!!! (or 2 or 10)
Thanks for the help so far folks!!
You have 'Download & Monitor' set in your profile, right? But was your list set to download/monitor when you last wrote to the scanner, to update it's database.
The *.hpe file you posted earlier looks to be correct, with the suggestion that you also flip it to ID Search instead of ID Scan. If it was set to be scanned (on the scanner itself, not just in your Sentinel Profile), as long as location was not turned on in the scanner (not just in your profile), you should not be getting 'nothing to scan'. Now, whether you would actually hear anything is another matter, but the scanner should have at least scanned.
On the scanner, not your in Sentinel:
Press
Menu
Select
Set Scan Selection and press
E (yes/enter)
On the next screen, scroll down and highlight
Select Lists to Monitor, press
E to select
At your list of Favorites, verify that the list that contains your Amarillo system shows
ON. If it shows
OFF, with the list highlighted, press
E to toggle it to on
Press
Menu again until you get back out to the main
Menu screen
At the
Menu screen, scroll down and select
Manage Favorites by pressing
E
At the
Select Favorites list screen, scroll down and select your Favorites list that contains Amarillo
Press
E to open it
At the next screen, scroll down & select
Use Location Control
Verify that
Off is highlighted on the next page. If
On is highlighted, highlight
Off & press
E to select.
Press
Menu a few times, until you get back out to the main
Menu screen
At the
Menu screen, scroll down to
Select Service Types and press
E
Review the various types, and verify that
Law Talk,
Fire Talk, and
EMS Talk show to be On. If one or more of them are
Off, highlight them & press
E to toggle to
On
By default, the only Service Types enabled in Sentinel (when first installed) are Dispatch for Law, Fire, EMS, & Multi. Make sure that the related Talk and Tac types for those categories are also enabled.
Attached is a modified file. It has your Amarillo P25 system, flipped to ID Search instead of ID Scan. I also added conventional frequencies for Randall & Potter Counties, plus Tx DPS. I appended ".txt' to the file due to forum file requirements. Save to your PC, and remove the txt extension, leaving it as Amarillo 2.hpe. Import into Sentinel, then try downloading it to the scanner, to see if you still get 'nothing to scan'.
