Clearing RS pro 106
Bill28227
Greenville, NC
Can anyone tell me if there is a way to clear all the info on a pro-106
From the Owner's Manual if you press the 0 key and then the 1 key during the WELCOME screen when you first turn on the scanner it should erase the working memory and change back to the defaults. The V-Memory is not affected. Discussed on page 86 along with other options. Good luck
gh6406
Dalton,Ga
Try this to reset Pro 106
2. Press 0 WHILE the scanner is displaying the
Welcome/Owner screen. The scanner displays:
System Tests:
Select a Test...
Exits if no key
is pressed
3. Press 1. The scanner displays:
Factory Init
Erase Memory
ENTER if APPROVE
CLEAR to EXIT
4. Press ENT. The scanner displays:
Initializing the
File System
Please Wait.....
File System
Initialized to
Defaults.
Press any key.
5. Press any key on the keypad to proceed. The
scanner displays:
GLOB EEPROM area
Initialized to
defaults.
Press any key.
6. Press any key on the keypad to exit
