CLMRN Scanning
jsm201
Danbury, CT
Day before yesterday I was scanning the CLMRN network. There is a repeater site near my location and I could see that I was picking up the control channels for that site. So I scanned only that site and was able to receive State Police calls and calls from CLMRN member communities. Then yesterday there was nothing on that site, I did not see any activity on the control channels or hear any calls.
What happened? Why would I be able to pick up transmissions one day and then nothing the next? Not even the control channels?
Maybe I just don't understand how that particular system works.
Regards,
Whiskey3JMC
_/|\_Surf's up, Happy DX!
Simulcastylvania, TE
What make & model scanner are you using? It may be an example of simulcast distortion but I don't want to draw any conclusions without this info. You're sure you have all the control channels programmed in?
jsm201
Danbury, CT
I am using a Uniden SDS100. I downloaded the frequencies for the site from the Database and have verified that they are all there, especially the control channels.
Whiskey3JMC
How close are you to the nearest site? Any luck scanning outdoors away from any potential sources of RFI? Are you able to pick up other signals (NOAA weather, etc)?
jsm201
Danbury, CT
I am pretty close to one of the sites, maybe two miles. I am able to pickup local police on their conventional system as well as a nearby airport.
I have scanned from outside on my porch and on the first and second floor of my house.
Whiskey3JMC
Maybe the site went offline? Do you have another receiver at your disposal you can use to test each control channel?
jsm201
Danbury, CT
Read this description of Affiliation on a trunked system for an explanation.
Good luck!
If I understand this correctly, this would explain what is happening.
But wouldn't the control channels still be active? I am not even picking up the control channels.
Just to verify that I understand, the only time there would be transmissions on the site I could hear is when there is an active radio, State Police for example, making calls on on that site? What if a State Police radio is, like me, just waiting for a call? Does that radio negotiate with the site somehow to let it know it is present? Which of course I can't do with my scanner?
jsm201
Danbury, CT
Yes, I considered this. If I wait it may come back. Yes, I have another receiver I can use to check the control channels. I will do that when I get a break and post the results here.
scanningct
Which site and control frequencies are you referring to?
Dave520
Connecticut
Is it possible that you activated an attenuator filter? Just a thought!
jsm201
Danbury, CT
I
I just used another radio to check the four control channels. They do not appear to be broadcasting, I did not hear the characteristic sound one hears for control data.
scanningct
Troop A Simulcast.
769.08125770.68125771.53125772.73125773.05625c773.95625c
851.275852.700c853.3125c
I'm in the Troop A area (Newtown) and picking up with no issue at this time., normal amount of traffic. We may be receiving from different towers though.
scanningct
Are you able to pickup any other sites? If you were able to pickup Troop A maybe your in range for Troop G, L, I. Possibly creating a new Favorite List on the SDS and importing Troop A again would reset any inadvertently changed settings.
Whiskey3JMC
Day before yesterday? New Year’s Day. Activity may have been curtailed due to the holiday…
This wouldn't explain why the OP can no longer pick up control data on more than one receiver. Activity or not, control channels should remain online
jsm201
Danbury, CT
Yes, I have another Favorites List with some other sites in it. I have never gotten any activity on any site except Troop A and Troop L Simulcast. Today I am seeing no activity on either, not even control channels.
Thank you all for your timely and informative responses. I am going to keep fiddling with my SDS100 and see what I can figure out. For me the tweaking and fiddling is part of the fun of scanning.
