CM300d
Hello. I just have one question to ask.
A company here in my town is using a CM300d Mobile in one of their machines.
I am just wondering what software you need for this radio. Is it just the MOTOTRBO software. I have version 10.0 (BUILD 510). Or is it another type of software.
Just need to know what software I will need to program this type of radio. If it's the one I have or another software.
Let me know. Thanks.
ramal121
Lots and lots of watts
Calif Whine Country
Yes the CM300D will use TRBO software and not the professional series. Latest for TRBO is V11.2 build 604.
Ok. I asked on another site and the person that replied told me that it uses all the same CPS Software.
So the software that I posted in my previous post, according to that guy will work.
So will this software I have work for that CM300d Radio or no. Because I am getting 2 different answers here.
Let me know.
Thanks.
vans113
Tennessee
The "D" stands for digital the cm300D will use mototrbo software to program it.
Yah I know the D stands for Digital lol.
It's just the other person that replied on here said that the version of the MOTOTRBO Software I have would not work and needed another version of it, and on another site a person a replied and told me it would.
So I just want to confirm and make sure that the version of software I have is the right one and will for sure work for this radio.
So let me know.
vans113
Tennessee
10.0 will work for it , but say i programmed it with the version 11.2 and you go to read the radio with cpd 10.0 it will not work then because I used a newer software.
Ok. All I have is that 10.0 version and would not be upgrading to a newer version unless for some reason I really needed to. So would not have to worry about that.
If I did upgrade the software sometime for some reason, I usually remove the old version and replace it with the newer one. So there would be no worries about me reading the radio with the newer software if I had it and then for some reason (if I still had the older version on my computer) go and use that one to try and program the radio again if it needed something else done.
So thanks for the reply and telling me that for sure this version I have 10.0 will work to read this radio and program it.
That is all I needed to know.
Thanks again.
WB0VHB
Mt. Union, Iowa
I believe you will also need a different programming cable than the standard RJ45 we have used for decades.
WB0VHB
Mt. Union, Iowa
I have a USB to RJ45 programming cable for programming CDM and CM series mobiles. It won't work for the CM300d.
You will need a PMKN4147A which will also work for the XPR2500 series.
Ok. And all the programming cables I have are not USB, they are all COM Port Cables. That you plug into your COM PORT in the back of your computer.
And a friend of mine told me that the cable I have that does most of the Motorola Radios out there will work for this CM300d or should work.
So since I have everything I need right now I should be good to go.
Just as long as if that CM300d, where they got it programmed from, as long as they used the 10.0 MotoTRBO Software I am good, if they used the newer version then I am out of luck in doing it.
But will see if and when I go there to see if I can read it, if it reads to my computer and I am all good to go to fix it up for them, if not then I won't be able to do it.
Thanks again.
Project25_MASTR
Monitoring
Texas
Trbo CPS sets programming cables up as network devices in newer versions. Can't say to that old of a CPS.
com501
The CM300d was released after Trbo 10. You will need Trbo CPS 11.0 or 11.0 and the correct CM300d programming cable to program this radio.
Just log onto your Motorola account and download the newest version from your account. Trbo CPS 11.0 and above requires Windows 7 or newer operating system.
Ok. Everyone on here and on another site and even a friend of mine who deals with a guy who deals with this stuff told me the 10.0 version I have will work. As long as that radio has not been programmed with the newer version, I am all good to go.
And I have a cable for it, the same COM PORT cable (which you plug into the COM PORT on the back of your computer) that I use to program every other Motorola Radio including the normal CM 300. I never use the USB programming cables always COM PORT.
And I don't have a Motorola account. So if I did get a chance to do this radio and it didn't work with the version I have 10.0, because it was programmed with the newer version. I will just get the newer version sometime from a friend of mine.
Thanks again for your replies.
Will see if what I have works if and when I go and do this radio.
KG4INW
Midlothian, VA
com501's correct. That radio came out after 10.0 so it won't recognize that model number. TRBO CPS also does not use comm ports so you need the newer USB cable. Ah, software piracy, got it!
Project25_MASTR
Monitoring
Texas
TRBO CPS sets up all comms as network devices. The programming cable you speak of is mainly built for the Radius mobiles. If it works on a CM300, it can't be used on a Maratrac.
Yah I do have a USB Cable for one of my TRBO portables. But the same cable I have that I use to program all other Motorola Radios according to a friend of mine and a friend of his who deals with Motorola stuff as well said that cable I have should work.
So as long as that radio wasn't programmed with the newer version of software, and was programmed using the 10.0 version I have I will be all good to go to fix it up for them, but if it doesn't read the radio, then I will know that they used the newer version of the software, which I will have to get, so I can do that radio.
And like I said the cable I have does most of all the Motorola Mobile Radio's. So it works on any. It does most of the Motorola Radios I have done so far.
Anyways will find out if they used the same version of software to program it as what I have now the 10.0. If and when I go and do it.
Thanks for the replies.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Cool guy, re-read what Com501 wrote. Ver 10 will NOT work. Neither will a serial cable...
Yes it will, a friend of mine who has a friend that deals with Motorola stuff, including software, told him the software version I have 10.0 will work on that radio. Just as long as that CM300d has not been programmed with the newer software version. If it has then I am out of luck until I get the newer software.
And yes that cable will or should work also.
So will find out if and when I go there to do that radio. If it doesn't read then that means they used the newer version of software to do it and will have to get it so I can then do it after I get it.
com501
DEAR COOLGUY:
I am a Motorola dealer. Your friend of a friend is full of beans. The CM300d cannot be programmed with any cable other than the new CM300d USB cable. IT IS A NEW RADIO and NEW CABLE.
The CM300d was added to the Trbo product line AFTER Trbo CPS 10.0. That means the MDF in the software will not recognize the radio.
You need to buy the correct version of the software and cable or quit fooling around with professional grade radios using out of date software.
Stop being a pirate. We have told you three times what you need. Enough said.
