cobourg trunk system
randyf
Strange days indeed
campbellford ontario canada
i would like to program cobourg trunking , i went into database found the frequencys but ido not see the custom frequency table listed, or is it needed. it is motorola type two smartnet
mikewazowski
Forums Manager
Oot and Aboot
Isn't Cobourg an 800Mhz system? If so, it doesn't need a custom frequency table.
randyf
Strange days indeed
cobourg trunking
after a wee bit of help from mike i put in the frequencys last night , then tonight i rushed through supper i even did the dishes to speed things up lol then drove down to cobourg to see if it would work , nothing but silence so i pull into the local tims to check my settings , i found the scanner was detecting the tower site as the strength bar was going full tilt , this is with four opp cars sitting in the lot too , i finnaly figured it out it was on control channel only so i clicked it off and it worked !!! 45 minutes down to cobourg 5 minutes there to find it works then back home again my wife thinks i am crazy
Jammin_Jay
Cobourg also simulcasts on 142.485 with voice inversion. So for those who live farther out. This frequency can be heard farther, usually more so then the Cobourg City Trunking system. If your not able to get a lock on the control channel from where u are
randyf
Strange days indeed
cobourg trunking
so can the bc396t do anything about the inversion , sometimes i can make out what is being said if i listen very close to what they are saying
mikewazowski
Forums Manager
Oot and Aboot
You'll need to feed the audio out to a computer running the Inversion program.
randyf
Strange days indeed
i see i had that once in my computer ages ago , i downloaded it from some place , i think cobourg has turned the power down as i can not get them anymore in campbellford , they did at one time come in very strong
VA3DBJ
Ontario Database Admin
The north repeater is now low power and directional. South-west lobe is the strongest towards the midway point between Port Hope and Cobourg.
paradoxnt
randyf said:
ok, can anyone tell me about the peterborough radio system can it be scanned
hemi said:
is that because they are encrypted?
I am actually going on a fishing trip to Peterborough Next weekend, and would be willing to try to scan it on the Pro 96 if it was possible.
exkalibur
York, Ontario
Oh, you can scan Peterborough all you want, they're an EDACS system.
However, you won't be happy with what you get. It's an encrypted system. However, the encryption has been known to be turned off in the past.
randyf
Strange days indeed
peterborough city p.s
yes i have heard voice on peterborough channels before , i see some frequencys are marked analog and some digital in the data base so i thought i could scan some of it
