Code plug clone ???
wa8pyr
Staff member
Lead Database Admin
Ohio
Can I clone or import a code plug from a 6550 to a Motorola 7550e both are vhf and I have 2.0 cps
Top-level drag and drop (if that even works with 2.0). You’ll likely have to fix a few errors, but that’s probably the fastest way.
K9KLC
Southwest, IL
You need to have two instances of 2.0 open at the same time. Read each radio with in each instance of CPS 2.0. On the one you want to copy from right click on "configuration"and select copy. Then do to the other one and right click on "configuration" and paste to that radio. You may have some errors come up at the bottom left, just sort those out one at a time and you'll be good to go. One radio may have features the other doesn't so just take your time and work thru any errors one at a time and it will work for you.
KD9RTX
Will scan and rx group lists copy in 2.0? I know in 16 they have to be manually recreated and populated.
K9KLC
Southwest, IL
For some reason it's been hit and miss for us. I've had some copy over but some you had to on and re-populate the scan list again. I can't comment as to the RX lists, the radios I've done for people and others that use 2.0 for our area don't use RX lists, the radios are mainly used for one TG at a time and at that, usually simplex. Being hams, we don't usually need too much fancy stuff LOL.
Frankly getting the contacts in there, the frequencies in there and other info over needing to start a new blank plug, to me, it's worth the trade off to just add the scan list back in if it needs done.
You will have to tell it to go ahead when it tells you the radio isn't the same and such but just tell it to go ahead and it's honestly saved some of us hours of programming between two different model number of radios.
K9KLC
Southwest, IL
I just did one from a 4550 to a 6550 VHF and it did not transfer to the scan lists. Everything was there on the left side to move it over but it just didn't populate the actual scanning list. I had two errors pertaining to capacity plus and corrected those in the "from" plug and then redid it and it was fine. All frequencies, contacts, and such transferred over fine. Compared to hand editing the changes I made in the original radio to copy it over, it was much much less time than having to do it by hand in the HT.
I think it was moving a plug from a XPR 4580 to a 5580 that it actually did take the scan list but I honestly don't remember. (or maybe visa versa) ??
Anyway valid question about the scan lists. Thanks for mentioning it.
