Codeplug for XTS2500 800mHz
dkshell
Pulaski, VA
Hey guys, I need a codeplug for this flashcode. 500098-00148C-6. 800mhHz, Model 3. Can anybody help?
mancow
N.E. Kansas
What for? You can't enable that flash by simply programming a radio with it with CPS.
dkshell
Pulaski, VA
I didn't say I was trying to do that. Don't always assume the worst, just like everyone else around here. That's the flash of my radio, and apparently I made an error in my programming and wanted to start fresh. I was simply seeking some assistance.
mancow
N.E. Kansas
I never assumed anything, you assumed I was assuming. I was curious if you happened to think that you could update the radio that way as many people often do. I think they often associate the term Astro with the older equipment that could be updated with a codeplug and RSS. That seems to be a common misconception.
dkshell
Pulaski, VA
My apologies, I have seen that also. Thinking that if they cram it in, it will work. I know this is not the case. Just needing some help.
mancow
N.E. Kansas
No worries.
As for cramming it in, It will work but requires depot software.
dkshell
Pulaski, VA
Even if it's the same flashcode, I wouldn't be able to use the clone function in the CPS?
mancow
N.E. Kansas
Oh I thought we were back on the flashing topic.
I never had a reason to use clone but I would think it should work in that aspect.
rescue161
KE4FHH
Hubert, NC
Sent you an email and a PM. I have a CP with that flash.
Edit:
I do not have the OPs requested CP. Mine is for 500018-00148C-3
Close, but no cigar. Sorry for the false alarm.
