Yaesu: Com port
W4ejv
Kodak
I am trying to get cp210x drivers to load but I find no com ports in device manager. I have checked on show hidden devices but no luck. I have tried on my old desktop, new desktop and a new laptop. I have plugged in my usb to uart cable to computer but not to radio. So I am looking for help. Is cp210x my only option to connect my yaesu ftdx10 to my computer ?
AK9R
Staff member
Super Moderator
Central Indiana
Are you loading the driver that you downloaded from Yaesu's website?
Did you install the driver before connecting the radio to the computer?
Because of the chips used for serial communications in the radio, you must use the driver specified by the radio manufacturer.
W4ejv
Kodak
I have tried both yaesu and silicon labs . yes driver installed before connection to radio. Thanks for your response
k6cpo
San Diego, CA
I found that to update the firmware on my FT5D and my FT70D handhelds, I had to first install a driver for the radio itself. I had the same issue until I discovered the driver doesn't show up in the Device Manager until the radio is connected and turned on.
W4ejv
Kodak
Thanks , I have connected to the radio and coms port still a no show but I will check for updates on ftdx10.
W4ejv
Kodak
Where did my post get move too and why ? Where should I have posted it to .
just for my own education. Thanks.
AK9R
Staff member
Super Moderator
Central Indiana
Your post was moved from Amateur Radio General to Amateur Radio Equipment which is a more appropriate forum for an equipment-related question such as yours.
bolo928
Allentown PA
Dumb question......Is the radio powered on? Cable has to be connected radio and radio powered on for the comport to appear.
W4ejv
Kodak
Yes cable connected and radio on . I have followed Yaesu instructions . Thanks for your reply
