BCD325P2/BCD996P2: Combinning Trunk Group & Quick Save Group
videobruce
Buffalo NY
Can I rename both systems (the 1st line) to the same name? The lines with the arrows are the ones to edit, correct?
The 2nd Qck Save Grp line remains the same? Is that correct also?
videobruce
Buffalo NY
But which lines, the ones with the arrows, the lines below them or both?
I welcome the replies, but only if they are complete, that don't raise more questions. What ever happened to step by step, detailed instructions? I see that all over, not just here. People assuming the person asking the questions has the same level of experience as they have which is rarely correct.
I re-named the top line of both the same, I made the 1st group Quick Key #1, the trunked system did not have that option. That didn't work, so I then went to the 2nd line on both groups, did the same there including adding the missing QK number the the trunk group. That apparently locked out the 1st group, the only one that could scanned was the trunk group, so I undid that and back to square one which is nowhere.
videobruce
Buffalo NY
A. It was NOT "instant" replies,
B. It was NOT "demanding"!
Especially when there are well over 700 'views'.
nessnet
What month is it?
The fastest way to NOT get a response, or get 'ghosted' is to cop an attitude.
Or, get known for snarky posts.
There are many here willing to help - as long as you TRY to make some effort to help yourself also....
Chill - you will get MUCH better results.
The above post is NOT the way to do that....
