Commander II not working with XTS5000
jtm1816
Martinez, GA
I recently purchased an XTS5000R with FPP (Model H18QDH9PW7AN) and Flash Code 5A0001-001106-8
I had an existing Commander II mic that works perfectly with my XTS3000
When I hook the same micup to the XTS5000 it does not function.
When searching through the Astro25 CPS i cannot find anything that allows me to "enable" a mic. What am I missing? I dont want to purchase a new mic if I dont have to.
Jeffrey
W9WSS
Retired LEO
Westmont, DuPage County, IL USA
To my knowledge, they are totally separate radios. I was informed that an XTS3000 is actually an Astro Saber on steroids. The 5K is a totally different animal.
jtm1816
Martinez, GA
Yes sir you are correct, they are completely different radios. However, all the documentation i read on the commander II mics states that the mic is supposed to be compatible with the xts3000 and xts5000. Was hoping that i was missing something
K2NEC
NA
What do you mean it doesn't function? Does nothing on the mic work? Are your contacts clean?
jtm1816
Martinez, GA
Yes sir, nothing on the mic functions, none of the buttons, including the PTT. I cleaned all of the contacts on both the radio and the microphone and tested it on my XTS3000 and it functioned flawlessly
mbnv992
AZ
The Commander 2’s should absolutely work with both the XTS5000 ( as well as the 3000 and even the MTS/HT1000’s the mics will work but the volume / side buttons won’t work ).
Something’s definitely up with your 5000.
natedawg1604
Colorado
In Astro 25 CPS there is a checkbox for the RSM to control channel/volume, I believe it's under radio wide settings/advanced; I'll double check tomorrow. You definitely need to check that box.
jtm1816
Martinez, GA
Just a heads up to everyone who responded. I ended up reaching out to the gentleman that sold it to me. He changed out the case and it began working immediately. Sounds like the connector going from the accessory panel to the radio was bad.
He did tell me that the commander mic I had purchased had a faulty mic as well
Thank you to everyone for helping me out with this
BD4ROQCN
i do have same experience with you and the root cause is the felx cable which install in the housing is bad.. it works perfectly after i jump the wire on the flex cable.
